scott011422
@scott011422
Went to the truck.
"Started it" to get a current reading since the truck was sitting a few hours in the 30'sF
This is where it was when I got home:
(Note that I take a screenshot just as I shutdown because I'm looking for a random severe parasitic draw. Hasn't happened in several days now)
Notice the SOC for both batteries.
12V = 91%
300V = 64% (top of the range with Ford's Hybrid strategy)
So a few minutes ago after about 4.5 hours of truck parked, as I said I started it. Keep in mind almost NOTHING happens when you start a Powerboost, it's in Park, and the HV Battery is at 6X%.
In fact if you turn off Climate and lights and heated seats/wheel, the truck is not going to make a peep, but it's definitely ON because the "Alternator" (DC/DC converter) is doing what an alternator does.
The screenshot above is a couple of minutes after the truck was "running" because the SOC was 87%, not 88%, when I first started it. Also the battery voltage was 13.1, not 14.4. So in the couple of minutes that I took to raise the hood and get a meter on the battery while the truck was on, both the 12V battery voltage and the SOC had increased marginally. Notice the Alternator is providing 47 Amps. (headlights off, climate off)
And whatever 12V Battery Current (the pid) actually is, it's reading 21Amps. Is this amps the battery is supplying? Or is 21 of the 47 amps from the alternator going to recharging the battery? (This is what I REALLY want to know)
So I shut the truck down. Hit the key Fob lock button. Floorboards tucked. Then I realized I left the phone in the truck. Unlocked doors. Zone lighting came on. Floorboards deployed.
I locked it up again. Floorboards tucked. Walked to the front of the truck to put a meter on the battery for you. The truck sensed me again and deployed the floorboards and zone lighting! Dang it. Lol
One more key Fob command and lights out, floorboards tucked.
I PUT THE KEYS in the RV.
Walked to the truck and put the meter on the posts.
12.57V
Why the BMS says it is at 88%?
I don't know.
And I bet if I started the truck it would be 87 or 86 after all my fumbling with lights and floorboards.
At face value those numbers look good. 90% for an AGM is roughly 12.62. So high 12.5's and high 80's SOC is at least in the ballpark. Your voltage might be a tad high since you "Started" the truck. After any charge is put into a battery its best to let the battery sit to fall down to rest or "Standing" voltage. Rule of thumb for 12v is an hour. Depends how long you charged it. May be worth redoing if you feel like it.
- Pop the hood when you get home so you don't have to wake the truck up more than necessary.
- Let the truck sit for at least an hour. Anything more makes no difference.
- Take battery voltage.
- Now you can use Forscan to check your SOC .
**EDIT**
Snakebitten, looking again at your pictures, It interesting that your first picture shows battery voltage at 12.4v Puts you about 70% SOC
**EDIT**
In looking at other forums and what Pavementends above is showing, 12.3ish volts seem to be where these 2021 and up fords like to sit for full charged. That's far from the 12.73v AGM would like to be at. Its very possible that Ford has at least an "OK" battery, there just abusing it by undercharging. AGM batteries are like the NI-CAD batteries of old power tools. They tend to form memory if not kept fully charged.
In the off chance Ford uses the BMS Reset as a "Tare" or "Zero" for the battery, I fully charged mine last night. Took 4 hours to charge and most of the night to condition, This was after the truck was showing 98% SOC and 12.3v at the battery. This morning I removed the charger and did the manual BMS Reset. When I got to work, (20ish min) Forscan was putting the battery at 100% SOC, 1 Amp of charging and 12.7v on shutdown. I'll keep an eye on it through the weekend.
Its obvious at this point that Ford isn't using the voltage to run the SOC. Maybe initially when the BMS is first initiated at the factory? There has to be something else since alot of us are seeing low voltage at high SOC. And since the charge level drops off, Ford isn't looking at the battery voltage, just the SOC.
