- Dec 22, 2019
- 430
- 905
- 1,683
- Purple State
- F-150
- Admin
Ford BMS Battery Monitoring System: How it Works, How to Properly Charge, How to Power Accessories.
Thank you for the information! My questions are in the video you point out to hook up accessories and battery chargers before the bms yet when u charge it looks like you are clamping it after the bms box.Ford BMS Battery Monitoring System: How it Works, How to Properly Charge, How to Power Accessories.
Excellent video - well done! It answers numerous questions that I had regarding BMS, but for me, it also raises a question.... It was stated several times (as well as graphically demonstrated on the laptop) that the truck was drawing 18A just sitting there, implying 18 parasitic amps. Wow! I was shocked by that - that's a lot! It also means that a traditional so-called "smart charger" (battery maintainer) would be of little use since most are rated at 5A or less. But at the end of the video, he then goes and turns the ignition off. What? The ignition was "ON" all of that time? When the ignition is "ON", most of the systems are energized, whereas most are not when the ignition is turned "OFF". So, I have to conclude - or at least assume - that when the truck is truly SHUT DOWN, it is not drawing 18A. Now I wonder what the true parasitic loss of energy really is....Ford BMS Battery Monitoring System: How it Works, How to Properly Charge, How to Power Accessories.
What you need is a 1.5 amp to 5 amp trickle charger/maintainer. Hook it up like it is shown in the video, plug it in , close the hood and walk away. There is plenty of info on this subject in this forum. I have a 1.5 amp battery tender, that is the brand and I have been using it since I got my truck in July of 2021. Others on this forum have used the NOCO brand. Both are excellent units. A larger unit will simply bring the battery to full charge sooner.Excellent video - well done! It answers numerous questions that I had regarding BMS, but for me, it also raises a question.... It was stated several times (as well as graphically demonstrated on the laptop) that the truck was drawing 18A just sitting there, implying 18 parasitic amps. Wow! I was shocked by that - that's a lot! It also means that a traditional so-called "smart charger" (battery maintainer) would be of little use since most are rated at 5A or less. But at the end of the video, he then goes and turns the ignition off. What? The ignition was "ON" all of that time? When the ignition is "ON", most of the systems are energized, whereas most are not when the ignition is turned "OFF". So, I have to conclude - or at least assume - that when the truck is truly SHUT DOWN, it is not drawing 18A. Now I wonder what the true parasitic loss of energy really is....
I am really interested in this because I do not drive my truck daily - I drive it when I actually need a truck. So, it may be driven daily, or it may sit for several days - or even a week or so - without being driven. For the first time, I had an experience similar to what was explained in the video. I went to the truck to get something out. None of the approach lights came on; I opened the door, and there were no interior / dome lights. I suspected right away that the BMS was doing its job and shut most everything down. Fortunately, it started just fine, but it did raise my awareness of real-life battery drain and I would like to address it - but now I'm not really sure how. Put a full-bore shop battery charger on it every other week? That's kind of a hassle.... Or am I approaching this thing with some wrong-minded thinking?
Thanks for your reply. I am quite aware of the NOCO battery charger products, as I own several of them - and like the other forum posters, I too think they are excellent products.What you need is a 1.5 amp to 5 amp trickle charger/maintainer. Hook it up like it is shown in the video, plug it in , close the hood and walk away. There is plenty of info on this subject in this forum. I have a 1.5 amp battery tender, that is the brand and I have been using it since I got my truck in July of 2021. Others on this forum have used the NOCO brand. Both are excellent units. A larger unit will simply bring the battery to full charge sooner.
On other threads I have seen reports that when you first shut off the truck, the high draw continues for a short while. After a short period however (10, 15 minutes?) modules start shutting themselves off and you end up with a draw of less than an amp. No problem for a tender to overcome that.Thanks for your reply. I am quite aware of the NOCO battery charger products, as I own several of them - and like the other forum posters, I too think they are excellent products.
My point was that according to the BMS educational video, there is a constant 18 amp draw (although I find that figure somewhat questionable, since the ignition was "ON"), and as the author stated - and demonstrated on the laptop - a 5 amp or even 10 amp charge still leaves the battery in a negative charge state. He had to turn the charger up to a minimum of 20 amps to overcome the 18A parasitic draw, yielding a 2A charge - the equivalent of a trickle charger. In other words, it takes a 20A charger to yield a 2A positive charge.
First, I am unaware of any 20A or larger battery maintainers. Secondly, this is all based on the video saying there is an 18A drain, which I really question, and THAT may be my underlying issue. Yes, there are many posts on this topic, as you have pointed out, but the 18A draw changes the discussion, IMHO. So, I'm still kind of lost as to how to proceed.
One reason for the ignition to be on in the video is because the scantool needs the ignition on to view the bms current pid. With the ignition off and all modules shut down the draw should be less than 500mA as Snakebitten said. a battery matainer 2-5A will be able recharge the battery and keep it charged.Okay, now we're getting somewhere! If those reports are accurate, then that would explain a lot of things, including the mysterious 18A parasitic draw of power. It would also mean that a regular 2A~5A battery maintainer would be sufficient after all, as you and others have suggested.
That's interesting, the WSM for my non-Powerboost sets limits an order of magnitude lower (bold added by me) ....Service Manual states that when troubleshooting a parasitic draw on a Powerboost, the tech is to shutdown the truck, lock doors, remove key Fob from area, and wait 75 minutes.
Draw should be 500ma (.5 Amp) or less.
