Ford 80A Charge Station Pro
RLXXI
Jun 10, 2021
110
92
S. E. Louisiana
2013 F 150, 2014 Escape, 2011 Suzuki DR 650SE
Auto tech
I have a solar panel array connected to an inverter.
Will I be able to use this for the Lightning?
Thank you.
Looks like you have a grid array like I do and if the grid goes down, the inverter shuts the array off. While the grid is alive and the sun is shining your array will feed the truck and the rest of your home before it sends any juice into the grid as per normal operation.
aeroengineer
Cory
Aug 29, 2021
ATL
F-150 Lightning Reservation Holder
Aerospace Engineer
Anyone know if you will need a 100A circuit to use this 80A charger or can it be limited to lower current? IE: 40/50A?
This is a question I have too. Right now I have a Tesla wall connector hard wired on a 60A circuit inside my garage. I’m trying to plan what modifications will be needed, especially since the Lightning probably won’t fit in the garage. The easiest solution would be to install the charger included with the extended range battery model in place of the Tesla charger if it can be set to “only” charge to 48A. I assume this solution - if possible - might also eliminate the backup power function too.
shutterbug
Joseph
May 20, 2021
1,183
1,146
Phoenix
I've no idea whether putting it on a 60A circuit would eliminate ability to use it for backup power (without any evidence, I suspect that it would not), but if that's the case, wouldn't the simplest solution be to sell the pro charger and invest in a tesla tap adapter?
aeroengineer
Cory
Aug 29, 2021
ATL
Aerospace Engineer
Probably. It would likely be the easiest/cheapest option. I’d just need to settle on a good way to run the cable/adapter combo out from the garage and close the door for overnight charging. I still might look into relocating the charger to the outside wall of the house near the garage. If I do that, I’d probably install a different EVSE so an adapter is no longer needed (Ford or other 3rd party brand) as long as the cost is reasonable. The electrician basically said I was using all the panel space I had when he put in the 60A circuit for the Tesla charger, so I doubt a 100A will be doable.
shutterbug
Joseph
May 20, 2021
1,183
1,146
Phoenix
So do you no longer have a tesla? And don't need to charge 2 vehicles? For a single vehicle charging I would recommend chargepoint flex. For multiple vehicles wallbox pulsar+ has gotten very good reviews and you can install multiple chargers that can share a single circuit.
Jer1983
Jeremy
Dec 15, 2021
30
Farmington
Honda Accord
Electrician
100 amp circuit USA - #1 aluminum or #3 copper, period. Rated using the 75 degree column because it’s a branch circuit not a service entrance cable.
Your best option is to pull #1 aluminum ser to wherever the charger is going to be located. Copper is outrageously expensive right now. If you don’t have a 200 amp service forget it. Also the Tesla chargers I’ve felt with had adjustable settings so you could install on lesser circuits but I doubt this will be the case since it can power your house.
rdr854
Oct 19, 2021
1,070
701
Northern Virginia
18 Volvo V90, 22 Ford F150 Lightning, 23 Outback
I have 200 amp service into the house with a gas dryer and gas furnace. The dryer uses 110 service. Am I good to go?
Jer1983
Jeremy
Dec 15, 2021
30
Farmington
Honda Accord
Electrician
110? Never heard of such a thing. 30amp for dryers and 30-60 for electric ranges.
look I need to be real with all you guys here. If you can not afford to have an electrician come out and do a load calculation on your house (should be free, you can probably find a calculator online) then pull a wire to your garage, probably between 1-5k depending on opening walls whatever, how are you paying for a 50-90k truck that a main feature relies on said charger? How do you not see the value in it.
rdr854
Oct 19, 2021
1,070
701
Northern Virginia
ah yes. Whoooosh
I can thank my engineer wife for that decision when we were having the house built 25 years ago. But who knew we would have EVs. Should of had the 240 volt line run anyways. Hindsight is always 20-20.
Jer1983
Jeremy
Dec 15, 2021
30
Farmington
Honda Accord
Electrician
Have never looked into gas dryers. I’ve never seen one. I’m an electrician and have worked in residential. Something in my brain has always told me hey those are gonna start fires but that’s probably about as true as cold water boiling faster than warm water. So it didn’t even register to me what you were talking about. Hey you should tell your engineer wife to look into how they’re banning gas everything in California
rdr854
Oct 19, 2021
1,070
701
Northern Virginia
I’m also with a fire dept, and we have run plenty of electric dryer fires over the years. Cause is generally a build up of lint.
rdr854
Oct 19, 2021
1,070
701
Northern Virginia
Now that I had the electrician out, hindsight is not 20-20 in this case. He advised that if we had a 240 circuit run to the laundry room next to the garage, the wiring still would not have been sufficient since a 100 amp circuit requires a more capable wire than what would otherwise have been run.
The county we live in is one of the more strict counties and requires actual load calculations. Apparently, there was an electrician who messed up and the load calculations are designed to prevent errors in the future that upset customers (our county treats the public as customers) and/or the electric utilities. By getting things correct upfront, the customer can make informed decisions.
