KartRacer25
Thanks. About how many turns did you folks turn them counterclockwise? I cant see the road with mine either. Just went out and did a 1/4 turn each for now, will check tonight.
Thanks ? I just used this exact setup.The first time I did, just to get a good look around.
You can just take out a 7mm screw or two on the felt wheel liner and pull it back a bit. That will get you enough room. I used a 1/4” ratchet with a short 2” extension and 10mm socket. It worked good. Aim them on a garage door or something and watch the alignment.
You have to push the fog button for them to be on. They'll also turn off if your high beams are on unless you enabled "Bambi Mode" with ForScan. I'm not sure if it's all models, but they can also turn on/off as cornering lights as well.Slightly related, but does anyone know what the conditions are for the fog lights to turn on? I have headlights set to auto. Occasionally when I hit the fog light button, they'll turn on. Other times, they won't. Last night when it was foggy, I noticed that the fogs would turn on by themselves when I was in a street-lit area, however in un-lit areas they would turn off which seems really counter-intuitive???
