Gros Ventre
- Bill
- Nov 13, 2021
- 47
- 2,303
- 1,544
- Western Wyoming
- Powerboost
The issues that the feds are ignoring, and should be sorted out in the marketplace, are how batteries charge, the temperature effects on capacity, & the losses incurred as power demand increases. 1st-batteries charge either by constant voltage or constant current, 2nd-temperature reduces capacity significantly when you go below about 30ºF, 3rd-as the current demand from the battery doubles, the losses in available power quadruple. Out here in my neck of the woods winter temperatures get down to -30ºF routinely. That can mean very low capacity and self heating of the battery drains power. Constant voltage charging means an ever decreasing rate. Constant current needs work since in some chemistries damage can occur. There are some chargers out there that counter this. The loss of power from current draw is fact, all you can do is use conductors with minimum resistance. When you force the marketplace, some dumb things will be done.
