Antimatter Tremor
- Jun 29, 2021
- 3
- 477
- 491
- 3rd Rock From The Sun
It's either a misprint or along with the Torsen front diff. you get 4.10 gears both front and rear like the Raptor. You cannot have different gear ratios.I don't think 4.10s is an option. I think the 4.10 Torsen front axle option on the builder needs to be updated as 3.73 to fit the Tremor build because 3.73s is the only option.
Hey guys, wondering is someone can give me a little help on my Tremor order, have a couple questions, going with the 402A package and I see it comes with the class 4 trailer hitch and the tow technology packages as part of 402A, do I need to order the optional trailer tow package (53A) to have the 10900 lbs. projected tow rating. 2nd question is about the Torsen front differential, rear axle is advertised as 3.73 ratio, the Torsen option is advertised at 4.10 ratio, so if I order this option will my rear axle ratio be changed to 4.10 to match the front, totally confused with this, would really appreciate any help.
I had the same confusion around the trailer tow package when I ordered mine. I thought the tech package had all I needed, but if I recall, it was missing some of the wiring and maybe the BLIS for towing. Anyway, I ended up adding the Trailer Tow Package. I'm not sure about the tow rating being affected or not.
I also ordered the Torsen front diff. My understanding is that this only affects the front and not the rear. So the rear will be 3.73 while the front will be 4.10. I believe the Torsen also raises your towing/payload rating by a couple hundred pounds, though.
Hope that helps. What color are you looking at?
You cannot have a front axle with a different ratio than the rear. Your transfer case will be destroyed. Its just like if you go with bigger tires than what your spare tire is and you get a flat tire on one of your rear tires. You're supposed to mount the smaller spare tire on the front, and move the good front tire to the rear and keep it in 2H.
Ordered an Antimatter Blue Tremor on 6/18
402A
Trailer Tow Package
Tray Style Floor Mats
Spry In Bed Liner
B&O Unleashed
I originally opted for the Torsen Front Diff., but my buddy (owns dealership) texted me and said the diff. option was late availability. With what's going on with the orders, I decided to drop it for now and I'm going to try and find out how long exactly "late availability" means.
