Enable Zone Lighting with Forscan?
Sneezy
Alex
Nov 29, 2022
272
437
Blueberry$1
2022 F150 XL
So I just bought myself a pair of elephant ears (tow mirrors) and I’m wondering if the zone lighting feature can be enabled on a vehicle that didn’t come with factory zone lighting? I was able to get the turn signals and puddle lamps to work via Forscan, however when I enable zone lighting in the body control module and APIM all it did was add the screen for zone lighting under the features tab on the center stack. I’m assuming this has something to do with the fact that I don’t have the actual hard buttons near my headlight switch, but I wanted to check if I was missing a step or if it was just the hardware itself that’s missing.
My truck is an XL
Pictured is the zone lighting screen that I didn’t have before, however none of the selections work (including the power button)
Ford F-150 Enable Zone Lighting with Forscan? A9037304-4055-4102-99B1-3108E3A367F5
Sneezy
Sneezy
Alex
Nov 29, 2022
272
437
Blueberry$1
2022 F150 XL
I just wanted to give a big shout out and thank you to @antho for taking the time and helping me work through this! I now have working spot lights and I couldn’t have done it without his help!
What a great community this is
For anyone who comes across this in the future, I had originally tried to to short cut my way through the coding process by doing the simple version of Forscan (which just had an enable/disable setting), rather than coding the actual values. Totally my mistake since I was intimidated by the Forscan spreadsheet.
Sneezy
Sneezy
Alex
Nov 29, 2022
272
437
Blueberry$1
2022 F150 XL
In the BCM under 726-84-02, you will want to change a 0 to a 1 in the first block and a 1 to a 0 in the second block. My factory code was 0000 0001 00B4. You will want to make changes xxx1 xxx0 xxxx
So my new code looked like 0001 0000 00B4
CaliF150
Greg
Dec 16, 2022
127
105
Most Expensive GAS State
2022 F150 SuperCrew STX 4x4 2.7 EcoBoost
Software Engineer
My truck is an XL
Did you purchase OEM tow mirrors and do you have the part number for the mirrors? I would love to do the same. Would I need to run any extra harness for the mirrors?
Thank you!
Sneezy
Sneezy
Alex
Nov 29, 2022
272
437
Blueberry$1
2022 F150 XL
Thank you!
I did not purchase OEM ones, I just got mine off Amazon
https://www.amazon.com/gp/aw/d/B09Q16CVBX/ref=yo_ii_img?ie=UTF8&psc=1
I couldn’t bring myself to spend nearly $1k for a set of OEM’s from the dealership, and these do everything I need them to.
No wiring modification or special harnesses are needed, the previous gen trucks did need an adapter harness on some trim levels. These will just require Forscan to enable all of the features, which for me I enabled the turn signals, puddle lamps and spotlights
They do need a slight trimming of the plastic housing to get it to fit over the rubber window trim. Here is the video I followed that helped show me what needed to be trimmed on the mirror housing (not my video, I was just a grateful viewer)
The install maybe took 30mins per side with all of the trimming so it’s a very straightforward job
CaliF150
Greg
Dec 16, 2022
127
105
Software Engineer
thank you very much for the information!
Blochead21
Feb 20, 2023
Pa
F150 Lightning
Damn I have a lightning and this doesn’t work. Even tried enabling the apim setting to enable 360 Lighting.
Jimboslice
Jim
Dec 14, 2023
Iowa
2021 f150 XL supercrew
Bricklayer
Is that all you changed to get the zone lighting on the menu to work?? Zone lighting is my first goal working with forscan.
sdennis1086
Scott
Jul 13, 2024
Brisbane Australia
2023 F150 Lariat
Fitter
Hi guys, can someone please outline all changes to enable zone lighting on a 23 F150? I have a Ford Australia delivered F150 Lariat and due to some compliance issues Ford Australia was required to disable it. I have been able to get the Zone lighting feature back on the Sync 4 but it does not power on. Any assistance would be much appreciated.
Ricksc
Rick
Feb 25, 2024
876
735
Bay area
2022 F-150
Thank you!
I have take offs of my 22 if you’re interested. They are manual fold manual telescoping but have bliss poodle lights that are listed in for sale section of this fourm
agmuscles
Adrian
Apr 15, 2025
bakersfield ca
2022 f150
realtor
How’s it going! That’s awesome that it worked out for you! Are you able to turn on other lights with adding the zone lighting feature? Thanks
