Airborne_Ape
- Chad
- Mar 19, 2021
- 1
- 120
- 154
- Atlantic Canada
- 2010, 2014, 2017, 2021 F150
You can. Temporarily disconnect the 12V battery (12V batteries if PowerBoost) and keep your FRDS session active.. Would have been a lot simpler and time saving overall if there was a way to just reboot the whole car, let it get settled and then go on to program the next module
I think you missed that halfway through the session you have to reconnect the VCMM to the OBD. I believe the physical bypass skips the calibration validation checks and tricks FRDS into thinking you have a brain dead module. Later when you are connected and selecting "No" you are bypassing an ECU wake command.Also, on the disconnecting the adapter from OBDII and then selecting the PMI, letting it fail, etc. I thought there were instructions in the troubleshooting steps for recovering modules that told you to simply say "No" when asked if the original module was installed. Isn't that the same thing? Or is disconnecting the adapter from the OBDII serving some other purpose?
It reminds me of a similar older process some guys use with IDS to flash junk yard PCMs as demonstrated in this video:
