STL04
Morhan
Feb 18, 2024
73
51
St. Louis
2022 Powerboost
How long does this take?
Its been going for like 40 min.
Ford F-150 ECU module programming guide using FDRS 20240416_093231
JEB
Aug 15, 2021
1,730
1,717
Northern Illinois
2021 F150 Lariat PB 502a
On another note-
I'm trying to "read all modules and systems," but the accessory power keeps timing out.
Questions
1) Will simply pressing the engine start button and turning the accessory power back on keep the reading mode going, or will I have to restart the entire process?
2) is there a way to turn off the time-out feature?
I’m not sure what you’re doing here, but I have never had a problem with my PB timing out during a network scan or programming. I just press the start button, leaving my foot off the brake pedal, and it stays in accessory mode until I either step on the brake and hit the button again to start the engine or press the button with my foot off the brake to turn accessory mode off.
cheesedogf150
CheeseDog
Aug 22, 2022
245
190
Toronto, Ontario, Canada
2022 F-150 Lariat
Just completed a hand full of FDRS updates, can I ask someone to check my vin to see if it's all clear?
I keep seeing the hvac module even tho I have updated it a couple times. Thanks
1FTFW1ED2NFC42626
rugedraw
Javier
Dec 14, 2021
4,714
5,537
Miami
Auto Sales
1FTFW1ED2NFC42626
That has happened to many people where the HVAC update won't clear from the list after you do it. You can ignore it.
cheesedogf150
CheeseDog
Aug 22, 2022
245
190
2022 F-150 Lariat
thanks!
cheesedogf150
CheeseDog
Aug 22, 2022
245
190
2022 F-150 Lariat
I guess the over the air updates were working pretty well for me
as fdrs only showed the following...
audio front control module
body control module
head lamp control module
hvac module
ipma module
power steering control module
fordtruckman2003
Apr 28, 2023
3,160
2,479
Indy
2021 F-150 FX4 Lariat
So, assuming I am looking at the correct thread, I suspect that I am on 1.7.1 as well.
1.7.1. is September 2021 update.
The next update is 2.1.0 from December 2021. We don't know when in December this update was pushed, but my truck was built on December 9, 2021, so there is a pretty good chance that my truck, although "Job 2", is still on 1.7.1.
Is this the thread you are referring to? https://www.f150gen14.com/forum/thr...-history-thread-f-150-lightning-mach-e.16968/
You are after 21174 that is on that power up.
Your update details under software update screen might show something or it could be blank.
If the automatic update options are disabled you are potentially on the broken version of APIM software.
Either way post VIN in lookup thread for someone to investigate I'm just speculating.
sbi
Sep 4, 2020
84
1,275
854
Upstate SC
I am on Software Version: 21223_PRODUCT Revision: 197 (SYNC Version) and my auto updates are on. I was told that I am stuck, waiting to dive into manual update with FDRS. Just wasn't sure where you can see which version you are on. Apparently SW version is different than SYNC version and you can only see it in FDRS from what I understand.
SilverPigeon
Apr 27, 2022
330
455
Australia
'23 F-150 KR 5.0L 157"WB RHD "Emaciated Edition"
Hopefully this clears it up a bit:
On the GitHub doc that tonesto7 makes, there is a correlation between the powerup version and the SYNC version. You can see this as a point in the description of the powerup version:
Ford F-150 ECU module programming guide using FDRS IMG_4600
Ford F-150 ECU module programming guide using FDRS IMG_4601
As you can see, your version is between the two that have been listed in the doc. Whether you are actually stuck is something I don't know, but that's where you can see the equivalence between OTA version and SYNC version. Most likely an FDRS session to get you nearer to current will get OTAs flowing for you (provided the OTA prerequisites are met).
fordtruckman2003
Apr 28, 2023
3,160
2,479
Indy
Yes to the above. You can guesstimate but not get a perfect idea. I was stuck on 22177 endlessly until I could give my truck it's first IPC update then the flood gates opened. Bought truck last year with no decimal point on odometer.
My truck history below and I was a little ahead of you. It is possible you may be in the same situation and my truck just happened to update everything except IPC until it got stuck.
5/6/23
22177 sync version at start 10:30AM
DDM Drivers door
PDM Passenger door
PCM Powertrain
ABS
GSM Gear shift
SCCM Steering column
BCM body control
CCM cruise control included these...
IMPA image processing (3 hours)
PSCM power steering
IPC instrument panel (CAN bus, 6 hours)
GWM gateway (USB)
APIM sync version 22192 (USB) 10:30PM
GWM gateway (CAN bus, 3 hours) 1:30AM
5/7/23
APIM sync version 22293, skipped over 22228 (6GB USB, Alexa update) 2:40PM
TCU Telemetrics (USB)
GWM gateway (USB)
APIM sync version 23031 (6GB USB)
GWM gateway (USB)
TCU Telemetrics (USB) 8PM
7/17/23
IPC update 4.3.3
DSP update
GWM update 4.3.5
OTA
8/12/23 22-PU1009-PPO-SI
10/17/23 4.3.6 (APIM) 23167
10/19/23 6.1.0 (GWM)
10/27/23 6.2.0 (GWM)
11/30/23 6.3.0 (APIM) 23291
12/01/23 6.4.0 (TCU)
12/12/23 6.5.0 (SCCM)
12/15/23 23-PU0813-DOR-UP2 (DOORS)
01/08/24 6.8.0 (IPC)
01/24/24 23-PU0110-RAD-PS (ACM)
03/01/24 23-PU1113-UNX-DC (TCU)
03/14/24 22-PU1009-TLC-CSM2 (BCM)
04/04/24 23-PU1009-SS-NS (ABS,PCM)
Once you fix your stuck truck eventually the updates should start working normally as several of us have experienced. :)
  • Like
Reactions: sbi
sbi
Sep 4, 2020
84
1,275
854
Upstate SC
Thank you both, @SilverPigeon and @fordtruckman2003 , for the explanation. At least now I am aware of the term "powerup" version :giggle:
To complete my full (hopefully) understanding of this - there is no way to see which powerup version I am currently on other than connecting to FDRS, correct? I see people post "Just got this version, just got that version", where do I see that?
SilverPigeon
Apr 27, 2022
330
455
Australia
Others may have better explanations of this, but as far as I know there are two ways the actual powerup version can be seen:
1. When an OTA has completed, a message will come up on the SYNC (infotainment) screen and / or
2. You get a notification in the FordPass app of the powerup version after an OTA.
3. (I'm not sure of this) if you or someone has access to PTS, it may be seen in that ford system. You can ask someone to check that on the "request VIN lookup" thread.
cheesedogf150
CheeseDog
Aug 22, 2022
245
190
2022 F-150 Lariat
@sbi
honestly the best way is to update your truck fully via fdrs, that way you know you are on the latest and it becomes your baseline regardless of what 'power up' version you are on as it's irrelevant.
track going forward from there
sbi
Sep 4, 2020
84
1,275
854
Upstate SC
Thanks. So there is no way other than after an update.
