fordtruckman2003
I also use 11.
Most likely simple issue with login email or password typo.
FYI, he's not yelling, he just has his CAPS LOCK key on for work a lot of the time, haha.ok, sorry about my post. i ll try to resolve other way . dont want to disturb here.
yEAH.. tHANKS FOR LETTING HIM KNOW. I dont think about it..FYI, he's not yelling, he just has his CAPS LOCK key on for work a lot of the time, haha.
good to knowFYI, he's not yelling, he just has his CAPS LOCK key on for work a lot of the time, haha.
The good news, even if he is yelling at you, you'll never know!good to know![]()
Send me your vinI was able to connect the FDRS and update some modules. I was able to update DSP, ACM, HCM, BCM, GWM, ABS and APIN (only an update of less than 1GB) Then another, much heavier 13GB file appeared, which took a little more than 1 hour to download. and then more than 1 hour to switch to the USB 3.0 pendrive.
When I want to update this version of the 13GB APIN and enter the USB, the update is in progress appears. do not remove the USB drive and Estimated Total Files Remaining 0 out of 62 files. After spending a while like this, a "USB error" message appears. When I click on it, it tells me "USB error 0. The update could not be completed because an error occurred."
What should I do about this? Tonight the 2-day license expires.
I have photos of the processes in case it is necessary.
i had VErsion 22082 Revision 411 , after first APIN update change to SYNC 4 VErsion 22125 Revision 428.Send me your vin
I was able to update the apin that was missing thanks to you.Send me your vin
Can't tell you what it's trying to push, but here's your updates availableMy truck is very insistent that I have an update I need to do. Can anyone tell me
what it is? Now that I’m testing OpenPilot I’m wary of installing updates.
1FTFW1ED1MFB68839
You have any issues getting the code to access your own connected vehicle data? Last time I had PTS we were having a disagreement on getting me access to owner vehicle information. I got the code emailed to me but website kept rejecting it.Just an FYI for everyone is case you didn't know, but I just found this here recently. In case you take your truck to the dealer to get "updated" and are curious what updates they actually do, if any, in PTS is gives the whole history for the VIN of what was done and when. I know it has come up a few times when people takes theirs to get updated, and the results vary at times. Here is a good way to check if you get a 72 hour pass to PTS or have someone check for you.
Case in point above, it's been fun to follow along as my dealer tries to figure out the P0299 code on my new 23.
