fordtruckman2003
I'd like to see benefits to update for my non-BC truck. Better lane centering and whatever but I can live with it as it is now.
Yep that's what I'm excited to try as well when I get my new 23 rig set up. There are few trouble spots I drive by a lot, so curious how 1.2 will handle them.I'd like to see benefits to update for my non-BC truck. Better lane centering and whatever but I can live with it as it is now.
I'm using an older version of one of these, never had a hiccup:
https://www.amazon.com/ASUS-VivoBoo...63b24bcb5&sp_csd=d2lkZ2V0TmFtZT1zcF9hdGY&th=1
here is a 2 in 1 version, no experience with that particular form factor:
https://www.amazon.com/ASUS-VivoBoo...d=1694405804&sprefix=asu,aps,2439&sr=8-4&th=1
Ah okay, I remember people saying be sure to stay with windows 10 so thats what I was trying to do.It’s really hard to find Windows 10 anymore, and there is a comparability mode to help with legacy programs, but it shouldn’t need it. There are plenty of success stories here on Windows 11.
Can confirm, been running Windows 11 for a long time and haven't had any troubles with FDRS.It’s really hard to find Windows 10 anymore, and there is a comparability mode to help with legacy programs, but it shouldn’t need it. There are plenty of success stories here on Windows 11.
Same issue here with no other updates showingFired up FDRS yesterday to do the GWM equivalent to OTA 4.3.5. Did everything until I got the "Application Finished" message. Performed network scan, GWM update is still there. Rebooted FDRS and tried again, and again the GWM update is still there after performing the update and another network scan.
Anyone else have issues with the latest GWM update? I still have the latest PCM update there that i haven't done because it will erase my tune and I don't feel like dealing with that for an update that means nothing to me. I don't think one thing has anything to do with the other, but strange that the update does not come off.
Have you checked to see if the software actually installed and it’s just a problem with FDRS failing to report the update to the as-built database? Use FORScan to read the software version directly from the module itself and compare it to the version FDRS is reporting. If FORScan shows a newer version, then the update installed fine and you’ll just need to wait for it to eventually clear from FDRS.Fired up FDRS yesterday to do the GWM equivalent to OTA 4.3.5. Did everything until I got the "Application Finished" message. Performed network scan, GWM update is still there. Rebooted FDRS and tried again, and again the GWM update is still there after performing the update and another network scan.
I didn't check, no. I did think about that being a possibility, but I had my kids with me last night, so I didn't want to spend to much time tinkering with the truck. I'll do that tonight.Have you checked to see if the software actually installed and it’s just a problem with FDRS failing to report the update to the as-built database? Use FORScan to read the software version directly from the module itself and compare it to the version FDRS is reporting. If FORScan shows a newer version, then the update installed fine and you’ll just need to wait for it to eventually clear from FDRS.
