Jesse-Infotainment
Only way is when the truck self reports. Otherwise you have to do a network scan. If the nodes that are reporting wonky are related to the things we worked on they will probably always report wonky.Was there any info on clearing up "corrupt" Node info from using the VXnano? Have a few modules that are showing some wonky info. I know using a mongoose and doing a scan in FDRS will fix it but are there any other alternatives? I dont have any module updates pending so trying to avoid a FDRS license and a Mongoose at this point. I looked into forscan to see if any procedure would update the node info but havent been successful. Thanks for any info!
