Ecoboost Oil and Filters
3DogKnight
Mar 22, 2021
33
320
381
Minnesota
2020 Escape Titanium - 2021 F150 XLT
100% retired
Mobil 1 full synthetic and NAPA Gold filter.
Icbmredrat
Wade
Nov 29, 2020
130
34
Toronto
F-150 XLT 4x4 Supercrew
Have a local parts store special on Liqid Moly 5W30 full synthetic. Any comments? It’s the longtime hi tec line of oil.
Thanks
EatDirtFartDust
Josh
Oct 23, 2021
154
138
St Louis, MO
2021 Ford F-150 XLT, 2015 Lincoln MKZ
Ford service manager
I have a 3.5EB and will change the oil every 5k miles with only Motorcraft oil and filter. The same stuff it came off the assembly line with, that I have been using in the ford shops I have worked in for the past 18+ years.
DT400
Darrell
Sep 14, 2021
204
149
79 Scout II, 90 Mustang gt, 95 F-150, 22 F-150
I will use Wix (NAPA Gold is made by Wix) or Motorcraft oil filters and NAPA gold air filters. I have tested the NAPA gold air filters and they work very well in dusty off road conditions for standard vehicles.
I will NOT use anything Fram or K&N...but do you own research.
Darrell
Gros Ventre
Nov 13, 2021
1,079
642
Western Wyoming
Powerboost
I use AmsOIl. Note that there's a GF-6 rating for the EcoBoost engine. My take on this is that the Gasoline Direct Injection of the engine calls for a slightly different formulation, so don't just pickup your typical weight of oil. As to Filters, Check out this site "CantonRacingProducts.com". They offer an 8 micron filter setup. I've used that on a very long lived Suburban engine. I also changed out the oils in all other components (transmission, transfer case, front & rear axles) to an Amsoil synthetic. Note that the oil specified for the transfer case is not the same ULV as for the transmission, it is just the "standard" LV oil. Also note that even though Ford & GM are using the same jointly developed 10R80 transmission they specify different oils. If you read the specs of the GM oil it's a somewhat higher viscosity than the Ford ULV specification. Some (including AmsOil) will tell you that the two transmissions use the same oil. Not so, each has different specs.
