Easiest way to get to my Payload and Towing Numbers?
WalterMitty
Aug 17, 2022
366
226
Chicagoland
2023 F150 Tremor
My truck is a 2023 F150 Tremor V8.
I'm trying to track down my payload (mainly the bed) max, as well as my towing max.
The only sticker I found in the door had the following info....
GVWR: 7050
Front GAWR: 3600
Rear GAWR: 3800
I missing the weight of the vehicle, as well as what it can tow.
Davexxxx
Mar 25, 2023
37
629
591
MO
If you don't have the infamous yellow sticker, you can open an account at ford.com, input your vin and there will be a link called vehicle dashboard. On that page, will be a link to a towing calculator. Your truck's payload and towing capacity will be there.
Beyond that, I'd ask your dealer about getting a replacement.
Buyer2021
Feb 9, 2021
1,530
2,626
TX
retired!
Yep, keep looking or contact your dealer - this sticker is required by law on F150 class trucks:
Ford F-150 Easiest way to get to my Payload and Towing Numbers? Payload
The combined weight of occupants and cargo should never exceed: xxx kg or xxxx lbs. is the 'VIN-specific payload' for your truck equipped as it left the factory (do not subtract the weight of fuel from that, it's already considered; do subtract the driver's weight from that, the driver is an occupant).
Your vehicle curb weight technically is the GVWR number from the other sticker minus the payload number from above (may not match exactly what you get on a CAT Scale but will be very close).
There is no 'sticker' showing your towing capacity, you must derive that from the applicable Trailer Towing Guide.
EricR
Eric
Jul 20, 2021
521
550
Boise, ID
... but it almost for certain you will run out of Payload well before you reach Towing Capacity.
diambo4life
Dec 31, 2021
756
772
OKC
2022 Lariat Screw 4x4
Assassin
How can that sticker be missing? Like...what the hell Ford?
WalterMitty
Aug 17, 2022
366
226
Chicagoland
2023 F150 Tremor
@Davexxxx @Buyer2021
Old eyes, and moving too fast, and I missed the all the info on what I thought was just the "Tire Pressuer" sticker!
I'm at 1544 lbs for the "should never exceed" amount.
I will have to spend some time Trailer Tower Guide link....that's going to take a bit of reading to figure out what my max tow capability is.
Thanks for all the info.
Davexxxx
Mar 25, 2023
37
629
591
MO
Studying the tow guides is good. Not trying to talk you out of it. There is lots of important stuff in there but honestly, the fastest way, is to go to the Ford.com page I mentioned. It will be specifically for your truck and whatever you input, for your expected cargo.
Buyer2021
Feb 9, 2021
1,530
2,626
TX
retired!
Take that time and read more thoroughly than you did the tire pressure sticker (gentle 'gig' in good spirits ;) :) (y)).
There's a wealth of good background information in there and a section on frontal area limitations that's missing on the mentioned shortcut webpage towing calculator.
Davexxxx
Mar 25, 2023
37
629
591
MO
I found that section particularly lacking.
They cite numbers, without being explicit in how to interpret them and then wave it all away by using the ambiguous statement that it may reduce performance. Well duh. Towing anything is going to reduce performance.
And not a peep about the aerodynamics of the trailer, as if they are all vertical walls.
I will be a stickler about payload and GCVR but they don't give you enough info on frontal area, to hold any sort of hard line.
WalterMitty
Aug 17, 2022
366
226
Chicagoland
2023 F150 Tremor
In my defense, I didn't have my reading glasses!!! :)
But as soon as you posted that pic with the tire pressures, I was like....D'oh!!!!!
WalterMitty
Aug 17, 2022
366
226
Chicagoland
2023 F150 Tremor
This was perfect for my needs. I only occasionally haul or tow stuff, and doubt I will approach any maxes.
Ballpark numbers for me are...
Payload: ~1,500
Tongue Weight: ~1,000
Towing Max: ~10,000
