Nightshade
- AJ
- Sep 4, 2021
- 26
- 471
- 233
- Alberta, Canada
- '22 Ford F-150 Lariat | '22 Ford F-350 S/D Tremor
- Firefighter Superintendent
Tested the DRL-disable option that can be disabled via FORScan, which is a great feature for us Canadians (not sure if it’s the same for US), I’ve gotten the codes from @Livnitup, huge credits to him! Works great, have zero issues. I tried it on mine and still have it for a few months now. I gave the same codes to my friend as he wants his disabled, works 100% on factory LED headlights! It’s a great option if you need it. The codes to change are below, ignore the “x” and write the number/letter that is in place. This will require the Sync 4 to be rebooted few times (2x for me) before you can see the Daytime Running Lights toggle on Sync 4 screen (Settings, Vehicle, Lighting):
IPC 720-02-01 xxEx xxxx xx--
APIM 7D0-09-01 xxxx x2xx xx--
BCM 726-21-01 0101 0101 01--
BCM 726-27-02 xx01 xxxx xx--
