Door Panel Rattle
RocketFistMooga
Clay
Jan 27, 2022
46
215
217
Pittsburgh
2022 F-150 Lariat Sport Powerboost.
I have a rattle coming from the plastic piece of door trim when driving. I attached a picture of the part that is rattling (google image not my truck). I can get it to go away by pushing on it really hard or banging it with my palm but it always comes back. Anyone else? Any recommendations? Maybe taking it off somehow and putting some foam or tape behind it to stabilize it?
Jglew82
Greg
Jan 31, 2022
71
99
DFW
2024 GMC Sierra 1500 Denali Ultimate
Facilities manager
All 4 of my doors rattle from the applique in front of the switches, below the one circled in the pic. Drives me out of my mind. It looks like they can be pried off and add foam or tesa tape behind it, but I wonder if anyone else has done it yet.
Ford Motor Company
Official Ford Account
Ford
May 26, 2021
2,830
1,439
Dearborn
F-150
Hi Clay. Can you send us a DM with your VIN and dealership info? I can look into this for you.
Graygoose2021
Nov 18, 2021
35
2,517
2,570
Oklahoma
Sales
Pull panel off, apply sound deadening around effected area.
OnceAnEagle
Walter
Aug 11, 2021
214
207
Kansas
2021 Ford F 150 Lariat Supercab Rapid Red
Have a driver's door rattle when driving over cobblestone streets at 20 MPH in nearby town, otherwise nothing.
LD50
Jan 7, 2022
104
96
IL
2019 Raptor, 2022 Lariat on order
Exact same problem with mine. Usually if I just apply light to moderate downward pressure just in front of the window switches it stops. On one trip I shoved a credit card between the panel that holds the window switch and the one that holds the mirror switches. That seemed to stop it for awhile but it did start again. I'd slide the card around or stuff it in another gap and it would stop again for a while. I've stuffed some small felt pieces in the gap in various places around that panel with no fix. I even popped the panel with the window switches off and cut a piece off of a pool noodle to apple pressure to the area from behind and still haven't found a permanent fix.
I will say that it's a testament to just how quiet the truck really is that the small rattle is enough to drive me crazy. I also thought I had an air leak around that door seal until I decided to fold the mirrors in and the sound went away. I'm not sure there's fix for that but I'm going to keep trying with the panel rattle.
Porpoise Hork
Bret
Aug 27, 2022
1,382
1,449
Houston
IT Sys Admin
Mine had this same rattle. It turns out the dealership's make ready team left the trailer plug adapter in the lower door pocket and it was causing the rattling but it sounded like it was coming from this exact same spot. It went away once I pulled the plug adapter out and put it a storage bag in the glovebox.
Thinking back to the two F150 service loaners I drove last year, they had the exact same rattle and both of them had the trailer harness plug in the door pocket...
Bandit Heeler
Nick
Aug 23, 2022
53
47
Memphis
2021 F150 STX 4x4 2.7
I had a similar issue when I got my 21 last August and it drove me crazy. I ended up pulling off the plastic trim above the door panel that covers the mirror bolts. I found that the mirror wires were attached with a plastic retainer “washer” that was about half way down the bolt. I seated the “washer” all the way to the nut and have not heard the sound since. I hope it’s that simple for you.
Dresdie
Apr 23, 2021
369
250
Ohio
2009 Acura TSX
Mine rattles right there too. Even on smooth road. Only thing in the cabin that unintentionally makes noise.
RocketFistMooga
RocketFistMooga
Clay
Jan 27, 2022
46
215
217
Pittsburgh
Last night I stuffed some foam weather stripping into the gap between the plastic panel and window switches. Trying to get some pressure against that panel. If I press on it the sound goes away. Will provide a report out on results.
Mosey
Jun 26, 2022
96
678
535
2021 F-150 Powerboost
I had what I thought was a door rattle but I finally found it was the trim around the dash vent. When I popped the trim off I discovered the push clip, a white Xmas tree-like thing, was bend down. It looked to me that when the trim was first installed that push clip was not aligned with the receiving hole. I bent it back and carefully attached the trim. No more rattle.
Porpoise Hork
Bret
Aug 27, 2022
1,382
1,449
Houston
IT Sys Admin
I discovered that mine had the same rattle. While in the process of replacing the OEM speakers I did this while putting it back together. No Rattle!
