awilli1010
Does the xlt sport package still have the floor shifter? It looks like it’s moved to the column on the Ford website.
Xlt Sport comes witht the console shifterDoes the xlt sport package still have the floor shifter? It looks like it’s moved to the column on the Ford website.
It depends on which package you option the truck with (300, 301A Mid, 302A High).Does the xlt sport package still have the floor shifter? It looks like it’s moved to the column on the Ford website.
So which one has the floor shifter?It depends on which package you option the truck with (300, 301A Mid, 302A High).
The Sport package does offer the floor/console shifter, but XLTs can be had with the column mounted shifter and a bench seat, a column mounted shifter with console (console will have storage instead of shifter), and console with console mounted shifter depending on what packages are combined together.
As was discussed above, it depends on how you option the truck.
OK, but again - will the Sport Appearance Package automatically include floor shifter, or does it require additional tweaks and changes to the package?The ONLY way to get the console shifter on an XLT is to opt for the sport appearance package. This requires 301a or above.
3.5L V6 EcoBoost 998 |
SuperCrew 4X4 W1E |
Floor Shifter |
Cruise Control |
Adaptive Cruise = Desireable |
Push Start |
Remote Start |
12" Center Console Display |
Power Rear Window |
Heated Seat |
Ventilated Seats = Optional |
I think you’ll need at least the XLT 302 with sport package to get most of what is on your list and it comes with the floor shifter. (My 302 has everything you want but no ventilated seats.) I think to get ventilated seats you’ll have to at least step up to lariat or higher. Someone else will have to chime in on that. I resisted looking at all the cool options on upper trim levels so I wouldn’t be tempted.OK, but again - will the Sport Appearance Package automatically include floor shifter, or does it require additional tweaks and changes to the package?
Also, can you have the Sports Appearanc with other packages, for example the FX4?
Pardon all the questions, first timer here (first truck, non-stop drooling ).
Basically, these are my "must haves":
3.5L V6 EcoBoost 998 SuperCrew 4X4 W1E Floor Shifter Cruise Control Adaptive Cruise = Desireable Push Start Remote Start 12" Center Console Display Power Rear Window Heated Seat Ventilated Seats = Optional
Thanks!
Thanks!
And do you have a floor or column shift (with the 302A)?I think you’ll need at least the XLT 302 with sport package to get most of what is on your list and it comes with the floor shifter. (My 302 has everything you want but no ventilated seats.) I think to get ventilated seats you’ll have to at least step up to lariat or higher. Someone else will have to chime in on that. I resisted looking at all the cool options on upper trim levels so I wouldn’t be tempted.
You can add on FX4 if you want, or max tow, etc. you’ll need the copilot 2.0 assist to get the adaptive cruise. I won’t buy another vehicle without adaptive cruise, of course the next time I buy a vehicle they will likely drive themselves anyways.
Thank you Kyle!I went to the Ford F-150 build and price and it looks like you’ll need the 302A High package for most of the options you want. Here is exactly what the website says as standard interior features for the XLT Sport Appearance Package:
If you want/opt for the Sports Appearance Package it will automatically give you the floor (gearshift handle built into the console) like you want.
There is an option that lists “40/console/40” (pictured above) that is available on any level of XLT, but I believe they Weill be equipped with a storage cubby and a column mounted gearshift. Like this:
Anyway, welcome to out humble forum! I think I speak for most of the crew here when we say we’re happy to help! Good luck with your build process, ask away if you need anything else!
I believe it was just that, a stock image. I had the same confusion on a few things for my build on the build and price website because of it.And do you have a floor or column shift (with the 302A)?
Thank you Kyle!
It was my understanding that the Sports Package will give you floor shift, but after building it online, the interior gallery showed column shifter, so it got me confused. Perhaps it's just a "stock" image and it does not adjust according to each "build", but I also didn't see any mention anywhere - not in the eSource book nor in the Order Guide - how to get the floor shift, other than Lariat and above.
Yes, floor shifter with the sport package. I think that is what “defines” the sport package along with the console. The stock picture of my truck didn’t show the floor/console shifter so seems like a glitch in the build and price?And do you have a floor or column shift (with the 302A)?
