Dash cam options?
Lon
Apr 30, 2021
51
Alberta
2021 F-150
Worker Bee
The Ford accessories dash cam has motion detection and will record when the vehicle is left unattended. Not 360 but total front and back. You can access all recorded incidents thru app on phone. I’ve had it on my 2020 Expedition for over a year and would recommend it if a dash cam is what your looking for. The app could be better but what app couldn’t?
I also have this set up from Ford plus it's supposedly plug and play. Super clean installation.
flatag
Tom
Feb 25, 2021
315
483
2021 Ford F-150 XLT FX4
FORD has 3 versions of OEM dash cams
The first version is a single forward camera with memory card and wired with an OBD-II port plug
the second version adds to the first package a rear window camera and cable
the third version adds to the first package an IR internal rear facing camera for the interior view.
2drunk2
May 6, 2021
29
2021 F150 Powerboost XLT
It looks like you are using fuse #2 and #35 to power your Thinkware U1000.
I actually tried the same two fuses before seeing this set-up in my 2021 F-150 Lariat and the constant feed to power the dash cam and work the radar module is not working for me.
which fuses did you hook the red and yellow wires too? Called Thinkware and they were useless.
Thanks
Bayside1, maybe this might help. I just wired a Thinkware F750 that I took from my previous vehicle and I used Fuse #4 for constant/ battery and #36 for accessory/ switched. Both are micro 2 fuses so I just used an add-a-circuit and then I used the common ground post next to the fuse block for the ground. Fuse 4 in my manual states vacant but the circuit is live with a factory 20 amp fuse. Continuous recording has had no issues when driving and parking mode picks up once the car is switched off. It doesnt appear that the camera is turning on by itself in the middle of the night either- just saying this as the previous car I had this installed had circuits that would activate 8 hours after engine shut off. My truck is a 21 Powerboost XLT. Just additional FYI, it seems all micro 2 add-a-circuits I had required sanding to fit the fuse slots except bussmann which fit perfectly. Hope this helps.
BaySide1
Kevin
Apr 29, 2021
59
35
Worcester, MA
2021 F-150 Lariat Super Crew 5.5Ft Bed
Medical Equipment Repair
I tried #4 previously but it did not power the camera for some reason.
ended up using #36 and #32 but that was short lived. I have the radar option and set the app to battery saver and it still killed the battery. Truck sat for almost two days.
I went ahead and ordered the Cellink Neo back up battery along with the extension battery. Done fooling around. Also found a Coupon for BlackBoxMy Car that saved me $31 on the order. Free Shipping and No Sales Tax
Tizzzo
Ed
Feb 5, 2021
450
385
California
2021 Lead Foot Gray XLT 5.0 Supercrew 4x4
Veteran
What is the app called?
Tizzzo
Ed
Feb 5, 2021
450
385
California
Veteran
I just installed the ford accessories front facing camera. Got it for free with my Ford Pass Reward points. Super easy installation, everything was plug and play and instructions were easy to understand. I was initially going to have Ford install it for me but after the reading the instructions and seeing how it was all plug and play I just ended up doing it myself in about 20 mins. Saved myself like $150 on install and it was free, cant beat that lol.
Chewza
Matt
Oct 29, 2020
121
145
Glen Allen, VA
'21 AMB Plat PB
Close up of where the wires are plugged in?
It's literally just a breakout to a USB-A Receptical. You replace the mirror's factory connection, and put this in between the mirror and the cable, and it gives you USB power. From there you power your camera via a USB power adapter.
petemill
Pete
Apr 20, 2021
187
155
Santa Barbara, California
'21 f-150 powerboost, '11 ford escape v6
Software
But it only has power whilst the vehicle is on and not parked, right?
Chewza
Matt
Oct 29, 2020
121
145
Glen Allen, VA
'21 AMB Plat PB
Correct. If you want to identify fuses for constant and running power, check my signature.
LUV2FORD
Jan 28, 2021
47
Tulsa OK
2021 F150 Platinum 6'7" bed, loaded. 6" BDS Lift
I have about 8 years of dash cam experience and have installed them on probably 6 cars. I've always done dual dash cams in the past. Seems like the rear of the vehicle is every bit as important as the front. This time I decided to go with a 3 channel dash cam (Viofo A139) so the interior is covered to. This camera is very small and discreet. I was worried the lack of a screen would bother me but the phone app seems to work just fine. You can change the settings, synchronize the time, playback videos, download videos all on you phone. Price is very reasonable considering it's a 3 channel. You can also get them on sale like I did last month for 20% off. So far very pleased. I really can't think of much of an improvement other than maybe going from 2k to 4k on the front, but I'm thrilled to have 2k. I did send them an email saying the app wasn't updating the firmware and they are looking into it. Not a big deal. I downloaded the latest firmware onto microSD card and it loaded. Pretty neat the phone will be able to update firmware though!! One modification I always do to my dash cams is to keep it powered on for 2 more hours after I get out of the vehicle (ACC power turns off). I do this with a timer relay. The relay senses when ACC power is removed and then starts a countdown. After a preset time it then removes power to dash cam. I really don't want the dash cam running all night long in my garage or all workday in the parking garage but I also don't want it to turn off immediately while I am at a restaurant or Home Depot, etc. So I decided 2 hours was the sweet spot!!
As is always the case in my forum posts........I hope this helps!!!
Again I almost feel like this is the perfect dash cam hence I bought 2 more of them while they were on sale (and no tax) on their website.
Amazon: Viofo A139
Viofo website
PC World Article
Ford F-150 Dash cam options? Screenshot_20210618-150326_VIOFO
Ford F-150 Dash cam options? Screenshot_20210618-150334_VIOFO
Ford F-150 Dash cam options? Screenshot_20210618-150341_VIOFO2
Eric
Eric
Jan 10, 2021
33
506
403
Toronto
2021 F150 XL STX
I got a super basic one from Amazon for under $60. It has front and rear view but I didn’t install the rear one.
I was nervous about installation as I’ve never done anything like that before but it was super easy. The SD card(32gb) was under $10 at Staples.
I don’t live in a dangerous area but there are a ton of the worst drivers in the country as well as insurance fraudsters around here so this dash cam is as necessary as a seatbelt.
it kind of distracts me because sometimes I would catch myself looking at it while driving so I just positioned it beside the mirror so that I can cover it with my sunvisor and it’s like it’s not even there.
And it’s sweet how it just comes on by itself as soon as I start the engine
longmountain
Jon
Apr 27, 2021
USA
'21 F150
Don't have the greatest pics as I took them in my garage as an after thought. I went with the Thinkware U1000 2channel dash cam with backup battery from blackboxmycar. Here are some install pics that I could take. The power wires from battery to front cam run along the headliner and down the C post to the battery mounted behind the 60 side of the rear seats. The cable for the rear cam runs along the headliner to the rear. The power for the battery runs along C post to headliner then down the B post and under the front door seal to the fuse box in the passenger seat.
In my pics the green and purple lines are supposed to represent the routing for the camera and power wires to battery and the red from battery to fuse box but i realize its not the greatest. If you guys need more pics or info I can retake pics and reply back.
Looks Like you used fuse 2 (delayed accessory) and fuse 37 (driver assistance) can you confirm and which was always on? I’m getting ready to do this exact thing with my rexing 4k front/rear combo. Thanks in advance, looks good!
Asphaltman
Jul 14, 2020
269
156
Salt Lake City
Entrepreneur
The Garmin ones have so far been very superior to the Amazon junk. Imho. Check them out.
Doggy-Dog
Ted
Apr 10, 2021
294
190
Western Michigan
2018 Pacifica Limited & 2021 Loaded Lariat
I installed my two today. They came from my 2019. Front was no problem. But the rear is. The '19 XLT had the camera just stuck on the headliner and never fell off. Well what ever they are using in the '21 Lariat is some material nothing will stick to. So I am still thinking of a solution.
They are both Aukey and I like them.
