How’s the build quality?22 lariat 5.0 sport 4x4View attachment 61780 View attachment 61781
Love the sound. I'll get some clips uploaded soon.
I'll get some clips of ASAPAwesome. Let's hear some clips. I have the extreme on mine with the black tips.
As far as fit and finish, it was perfect. The trick is to mount everything loosely...use a jack stand to position the pipes where you want the angles to be and start tightening from the front to the rear. I threw the poorly printed black and white instructions that were sent with it into the trash and instead used the color PDF instructions that's on their site .
I set mine to get real close but once you torque things down, they should not move much. There is a hanger close to the tips that should restrict that movement. The instructions did a poor job of showing you where they should go so you should be able to figure which goes to the driver/passenger side. Mine makes no contact whatsover. ..and it shouldn't if you have tightened down all those slip joints. I pushed mine "in" as far as I could as I don't want them sticking past the rear bumper.I'll get some clips of ASAP
Question do your tips came out real close to the rear bumper? Minor pretty close but they do have those isolator pads or grammates. But. But it seems if you hit a bump pretty hard they might raise up and hit the bumper
those exhaust tips protrude out much further than what i would have hoped for..Sorry in garage didn't want to wake neighbors
gotta see it to believe itThey can be adjusted bud.
