No problem Mr. Pushrods. What is your preference between the cloud and console shifter?Ok thanks for that information Eric.
You’ll only get it in the console if you got the sport model but I think when you get to the other trims like Lariat and above you automatically get the console shifter if you have a console and not the 40/20/40 configuration. That’s just from what I’ve seen on some photos but I may be wrong about that. Might be an option.I have the XLT 302A with 40/console/40 and my shifter is on the steering wheel.
Eric, I believe you are correct. If have not found an option for the shifter location by itself and if you look at the interior pictures on the builder site, you can see the shifter only shows up on the floor when the sport trim is selected.You’ll only get it in the console if you got the sport model but I think when you get to the other trims like Lariat and above you automatically get the console shifter if you have a console and not the 40/20/40 configuration. That’s just from what I’ve seen on some photos but I may be wrong about that. Might be an option.
I originally ordered the XLT Sport but then switched to XTR to avoid that new fold down shifter.Eric, I believe you are correct. If have not found an option for the shifter location by itself and if you look at the interior pictures on the builder site, you can see the shifter only shows up on the floor when the sport trim is selected.
I have a powerboost 302a sport on order and after seeing some other XLTs with the column shifter I was curious why some had console shifter. I really don't have a preference as my current XLT has a column shift and works fine so that you can seat someone in the middle on the front seat. My new order has the console so I assumed it had a shifter there, but then I saw an xlt with the column shifter and wondered what option gave it to me. I prefer the console shifter when there is a console present..No problem Mr. Pushrods. What is your preference between the cloud and console shifter?
