CEL - Inlet Pipe w/ Heat Exchanger
SeanV313
Sean
Mar 26, 2024
277
237
Website
www.linkedin.com
2024 F150 502A w/ PB, BAP, BUP, FX4
Fleet Vehicle Program Manager
Ford F-150 CEL - Inlet Pipe w/ Heat Exchanger 2024-05-17 12_30_12-Messages for web
I had to extend my lease by two months while I wait for Ford to schedule and build my replacement 2024 F150... And this is what I get in return for waiting.
JEB
Aug 15, 2021
1,901
1,901
US
2021 F150 Lariat PB 502a
There is a new SSM out that instructs techs to check the sensor connectors for corrosion or damage before replacing the inlet pipe/heat exchanger. It might apply to your situation and will probably save you some cash If this is the problem.
SSM 52543 2021-2024 F-150 3.5L Full Hybrid Electric Vehicle (FHEV), 2020-2024 Explorer 3.3L FHEV, 2020-2024 Escape 2.5L FHEV, 2022-2024 Maverick 2.5L FHEV - Illuminated Malfunction Indicator Lamp (MIL) With Diagnostic Trouble Code (DTC) P237F And/Or P2C23
Some 2021-2024 F-150-3.5L FHEV, 2020-2024 Explorer 3.3L FHEV, 2020-2024 Escape 2.5L FHEV, and 2022-2024 Maverick 2.5L FHEV vehicles may exhibit an illuminated MIL with DTC P237F and/or P2C23 stored in the powertrain control module (PCM) and no affect on drivability. This may be due to seal damage, corrosion and/or water intrusion in the exhaust coolant temperature (ECT) sensors 3 and/or 4 connector. Visual inspection should be completed on ECT3 and ECT4 sensors and mating connections for seal damage, water intrusion, and corrosion. If seal damage, water intrusion or corrosion is present, repair per cell 5 of the Wiring Diagram, then apply Motorcraft® XG-12 Electrical Grease to the female/vehicle side of the harness. This inspection of ECT3 and ECT4 sensors should be completed prior to starting the appropriate pinpoint test in Section 303-03 of the Workshop Manual (WSM). If DTCs P237F and/or P2C23 do not return, no further action is necessary and the replacement of the entire exhaust heat exchanger assembly is not required. If P237F and/or P2C23 returns, follow the pinpoint test in Section 303-03 of theWSM for further diagnostics.
Hans Moleman
Mar 3, 2024
265
159
SF Bay
2023 XLT 302A Powerboost FX4 Sport
If it’s a lease just wait it out and turn it like that.
SeanV313
SeanV313
Sean
Mar 26, 2024
277
237
Website
www.linkedin.com
Thanks! I let the dealership service advisor know about this.
SeanV313
SeanV313
Sean
Mar 26, 2024
277
237
Website
www.linkedin.com
