Aron
There's more to it than just tires, though I agree that swapping out the tires for LT tires will help with towing, everything else being equal.Several generations ago, the only difference for the tow rating difference between the single rear tire (non-dually) F250 & the F350, was just the ply rating on the factory installed tires. That was it. When Ford added higher ply tires to the F250, Ford slapped an F350 emblem on it and the rating increased.
The reason that yellow sticker lists the stock tires and at what PSI is because those crap stock tires are the limiting factor as they were chosen for economy and a soft ride.
So, the question is, what is the load rating or limitations now that my truck is running a proper LT tire? Is it the brakes, the rear springs, the cooling capacity of the transmission, the rear diff, the hubs, the Al wheels themselves?
Something doesn't add up here for me...
The payload rating is the GVWR minus the weight of the truck, so a heavier truck will have less payload, even if that heavier weight won't affect towing much at all (such as a moonroof). I don't know how the Ford engineers precisely calculate the GVWR, but it's some combination of suspension, frame, axles, brakes, cooling capacity, and probably some other things that I'm not thinking about at the moment. You may be able to upgrade some of these items (suspension, brakes, transmission cooler), but others (frame) likely aren't feasible.
The GVWR is rated to meet certain testing standards (e.g., the total combined weight of the truck and trailer must stop completely from a certain speed in a certain distance); it doesn't necesarily mean that your truck will break if you exceed any given rating (though it also might, depending upon conditions).
