Can Interior Work Surface be used while the truck shifter is in Drive?
charliecbp
Charlie
Oct 19, 2020
276
193
Key West, Florida
2021 F 150 Limited PowerBoost
You guys with the interior work surface, can this be used while the truck shifter is in drive? In other words does the shifter only stow in park or can you put it in drive and then stow it and open the work surface
discothan
Jan 4, 2021
639
590
SW Michigan
2021 F150 XLT
This is not possible.
If your shifter is in the middle console, the work surface can not be fully deployed unless the shifter is in the down position. I do not know if the work surface can be optioned when the shifter is in the steering column. I also do not know if the OEM work surface can be ordered/installed separately.
charliecbp
charliecbp
Charlie
Oct 19, 2020
276
193
Key West, Florida
I understand the shifter has to be down with a center console, question is can the shifter be put in "drive" and then put in the down position or can it only be put in the down position while in "park"
papa.charlie
Ryan
Dec 1, 2020
61
75
Ontario, Canada
2021 Lariat SCrew F-150 PB FX4
Everything I've seen says no it can't be put down while in drive, only while in park. But if you can do this in drive, it seems a little sketchy to have to potentially move your lunch and laptop, fold up the work surface, and press the button to pop the shifter back up just to put the truck in park.
05RubiconLJ
Matt
Aug 6, 2020
40
881
755
Arkansas
I believe there has been hard confirmation, the shifter will only lower while in park. As Ford has switched to shift by wire, the electronics will lock out the lowering button while in any gear other than Park. I am certain someone will find a software workaround. From a safety perspective, seems unsafe, but I can see how it would be beneficial.
Jbrantner
Jason
Jan 8, 2021
Wisconsin
2021 f-150 xlt sport
Product Specialist
My buddy just bought a 2021 XLT chrome appearance. He has the center console with column shift and that works out. Sport package like mine with the console shift, not so much.
TxTech
May 21, 2020
37
31
Jeep Wrangler Rubicon JL
Have seen videos of people pushing the button to fold it down while driving and can confirm it won’t fold down.
lrtexasman
Larry
Dec 15, 2020
Rockwall, TX
Tundra, CX-5, Rogue Sport, Lincoln MKX
Console shifter will only fold down from Park.
snyce1
Steve
Dec 6, 2021
258
86
Schenectady,NY
21' F150PB PLATINUM, 17'Escape, 15'expeditionEL
The surface will unfold but cant lay flat . The truck has to be in park for shifter to lay flat
