dog_tired
Window Sticker will tell you as well: DRB for DearbornI thought the 11th digit of your VIN tells you + on my 2016 it was labeled inside the driver door area.
i don’t have the truck to look at the sticker or door. It’s at the dealer for who knows how long. My Ford pass shows the VIN # as 1FTFW1ED2MFA49519Window Sticker will tell you as well: DRB for Dearborn
You can also check the sticker on the lower corner of the windshield on the passenger side.No, I don’t.
Yeah right, more like they want sell the trucks on their lot!Got my truck back today with the new module for the turn signal. They took the part from the assembly plant and shipped it. I was told they couldn’t pull one out of a truck they already had on the lot because once it was programmed for a specific truck it couldn’t be programmed for a different truck.
Probably told you this ‘cause you might accept the explanation, but not believe it.I was told they couldn’t pull one out of a truck they already had on the lot because once it was programmed for a specific truck it couldn’t be programmed for a different truck.
