Box tied down anchors defective?
chris
Feb 15, 2021
Alliston, ON
2021, 2012, 2008, 2004, F 150
production line associate
Anyone else have their truck come with these? Mine are defective and won’t slide in to the anchor points. I even went as far as taking the anchor point off and try it free hand, and no go. Covered under warranty maybe?
I had the same thought, ended up using a hammer 'gently'
Bryan Simon
Bryan
Sep 16, 2020
1,458
1,101
San Antonio, Texas
Maintenance
I handled this the easy way ( insert “EASY” button here)
had the dealer put them in before I picked up the truck.
Roger350
Roger
Aug 9, 2020
415
408
2011 Evo MR, 2015 Sonata Hybrid, 2007 Tahoe - Being Replaced by 2021 F-150
Being this will be my first F150, and first pickup in 14 years, what is the lock for on these tie downs for? Is it just to keep someone from stealing the tie down itself, or can you use it to somehow lock the things you tie to it?
Jim Bandy
James
Oct 29, 2020
637
501
28306
2021 F150 Limited 4x4 Powerboost (Hybrid)
Same issue on my 2016 Plat- gotta play with them as they can be a real PIA - Pain In Ass. Video posted is great and sums it up.
Blue Beast
Jan 14, 2021
51
95403
Toyota Tundra
I couldn't get them on either, busted a knuckle in the process. I used a round file to make the channels a wee bit larger, worked great
Bryan Simon
Bryan
Sep 16, 2020
1,458
1,101
San Antonio, Texas
Maintenance
pretty sure they are there for securing the cleats themselves and also makes it possible to secure most any cargo from theft.
generator, welder, toolbox etc.
CnB150Lariat
Jan 9, 2021
172
180
2021 F150 Lariat, PB, Fx4, SuperCrew w/5.5 Bed
it’s so that the tie downs can’t be easily removed. I believe there are some Ford accessories that “lock” into them possibly?
GrandSport
Joe
Oct 14, 2020
E Northport NY
2017 f150, 2021 on order
Admin
I had this same problem with my '21. I had to take the brackets off and use a rubber mallet to get them in place too. The box links on my '17 was much easier to get in.
N1TJ
Tyler
Jan 23, 2021
76
91
Mechanicsburg, PA
2021 F150 Lariat EB 4x4 - Oxford White
Air Traffic Controller • USAF Veteran
I don't think they are defective, but they are a pain to get in. You have to have them exactly square and flat. Then they will walk in.
This was exactly right! No mallet necessary. I gave up on the first attempt, read this, then went back out focusing on getting them super flat by rotating upwards from the bottom... voila. Walked right up with little effort! ?
jcaspar
Feb 23, 2021
445
414
Sacramento CA
2021 F-150 4x4
My truck came with them installed. Only noticed the tightness when I was testing them out. I filed then a bit which makes it easier.
Lugusthedog
Lugus
Feb 16, 2021
43
52
Sun City Arizona
2021 F150 Platinum Maxtow 3.5 EB
Insert straight in, give it a 30-45 degree twist so you catch one edge then straight it out as you yank it up. Extremely tight but doable.
JohngaltinOC
Scott
Mar 11, 2021
198
128
Orange County ca
2021 F150 lariat EB
Finance
I thought I was going nuts. Experienced just about everything mentioned here. I think I finally put my finger on it. Figured out it wasn't sprayed bed liner, wasn't that the tie down itself was too tight or the groove was too narrow. It looks like the metal bracket was given a concave curve when the manufacturer stamped that hole pattern where the tie down slides into it. It binds up when we start sliding it up. Had to remove one mounting plate to be able to see what's going on. Going to try the sideways thing and then the hammer before taking it into dealer....I guess not enough service guys have bitched to Ford about it yet
YOCUBED
Oct 28, 2020
56
64
Tuscaloosa, AL
2020 GLE 450, 2016 BMW M3, 2021 F150 Limited
Emergency Physician
Mine were terribly hard and tight to get in. I ended up having to get pretty aggressive with a rubber mallet and eventually it went in. There was definitely some excess plastic material in the channels of the cleats that required filing down. But they aren't going anywhere now
brnt
Nov 29, 2020
141
137
UT
'21 Lariat
There's a trick to putting the cleats on. You have to rock them forward and back while lifting. If you're facing the anchor point with the cleat lined up in the hole, lift while tipping the cleat up and down in front. It'll still be tight, but it will slide on without tools or trimming the cleat.
