revinkev
- Kevin
- Jan 23, 2024
- 0
- 26
- 18
- Port Orchard, WA
- 2022 F150 Lariat XLT Power Boost
- IT Director
Yep Tried that too.If you have not already done so, download from the Opus/IVS website the J2534 Toolbox application. Plug your Mongoose into your laptop and run the application. You’ll see a tab that says “Support” that has a series of diagnostics that will check your installation, the connection to the truck via the OBD port and a couple of diagnostics for the device itself, like newer drivers. The diagnostic tests are Install Check, Vehicle Check and Device Check. Run all of them and if a test flags something, follow the instructions. You might see an update under Device Check for a newer driver. I did recently that took my driver from 1.0.18.0 to 1.0.68.0. See if that helps.
When I select the device and click Auto Login it says Device missing.
Tried multiple USB Ports and 2 Different laptops.
Blinking Green when plugged in so I know it's connected.
Just think it's a bad device.
