Jesse-Infotainment
They should.If I tell them that they'll know what it means? Or should I just let them buy the truck back? My Lightning Platinum was built last week...
But so you can tell them.
Open FDRS. DO the network scan. Select Gateway module when they are at the screen with map of modules. When they select Gateway(GWM) there will be a list that only pertains to the Gateway on the right hand side.
Select PMI(Programmable Module Installation)
It will bring up some prompts. When asked if the original module is installed they must select NO!
This will prompt FDRS to NOT pull the info from the old module it will pull it from the database.
The issue is the Gateway info changes with the update. Your has not for whatever reason. The PMI will update the config to what it needs to be.
I can tell immediately after the PMI if it worked or not. If they try it tell me right after and Ill tell you if it worked.
Your truck is fully up to date and from what is reflected online the gateway is the only thing not configured correctly.
