Kodiak
Shout out to Buyer2021 for supplying the pdf wiring diagrams and who’s testing made this mod possible.
Background – I love the BLIS system, but I found it lacking in a couple of areas. After driving a vehicle that had the BLIS warning in the side mirror and in a HUD, this just made the deficiencies even worse to me. Maybe it is due to age, but I just found my peripheral vision was not enough to alert me to BLIS activation and I would have to physically turn my head, then refocus on the BLIS in the side mirror, then either focus on the side mirror or return my head to looking forward if BLIS was active. Direct sunlight did not help either. I wanted something more.
(3) BLIS - Alternative Option For Interior Signal Experiment (Edit) | F150gen14.com -- 2021+ Ford F-150, Tremor, Raptor Forum (14th Gen) | Owners, News, Discussions
This link is to a thread that was previously started and shows a little of the evolution about this mod. This goes into the background and why this was settled on the positioning and what is easily possible for this mod. The wiring and an easy spot to place the additional BLIS light had a lot to do with everything.
In the first picture you will see that I settled on a Chanzon 5mm 12v prewired frosted LED (Amazon) and a metal LED housing that had the LED just sticking out from the housing. I tried about 4 different 12v LED’s and I settled on the amber (orange) color for that frosted LED. This was the most pleasing look and brightness IMO. I also tried about 4 different housings and settled on the metal housing with the silver finish. This housing felt far more robust than the plastic housings and although I could not use the provided LED holder for those housings, I was able to use some rubber electrical tape and made a plug myself. The housing for the 5mm LED’s come with a plug that holds the LED in place, but that is for an LED that is plain without any resistor. I used the LED with the resistor already attached so I improvised. You will see this in the picture of the LED and housings. BLIS 1.
This next picture just shows the positioning of where I wanted to place the housing for the new additional BLIS light. Be sure your positioning does not interfere with any connectors or bolts.
This next picture shows the truck’s interior cover for the mirror wiring. This could not be more convenient.
In the wiring diagram for the LEFT BLIS MIRROR (Driver side) you will see the diagram for connection C521. This shows that wires 13 and 20 are the wires that are connected with the BLIS alert in the mirror. In the picture you will see the test set up with the LED positive lead (orange) going to wire 13 and the LED’s ground wire (black) going to wire 20. This worked perfectly with the truck’s regular BLIS alert in the side mirror and both the alert and new LED activated together. I used the Posi Tap 20-22 gauge to tap into those original BLIS wires (13 and 20) to make my connection for the additional LED.
NOTE: In the wiring diagram pdf (at the bottom of this post) you see what the wiring diagram C521 would look like from the other side of the connection. When you look at the wires after removing that cover you are seeing a mirror image of the wires in the pdf. You can tell by the side that the locking connector is on and space 21 has no wire in it. Use this missing space (21) as your guide.
NOTE: The passenger side connection (C622) was actually completely flipped over in the truck. Again you have to use the empty wire space (21) to be your judge. Wires 13 and 20 are the also the BLIS wires for the passenger side so use their location in relation to the missing 21 wire and look at the wires colors in the wiring pdf file. Just double check, and it is easy.
These next pictures just show the test LED removed and the final LED housing attached to the plastic cover in the position that I determined earlier. I used a 5/16 drill bit for this particular housing and tested it on a block of wood first. The hole for the LED and housing was perfect. I then threaded the wires through and attached them to the Posi Taps and tightened down the housing. Then just snapped the interior cover back on.
These next pictures show the additional alert LED both on and off. The direct sunlight washed out the truck’s side mirror BLIS but it lights up just the same as before. Although this is really just a limitation of the camera’s exposure it highlights one of the issues I have when direct sunlight is on that mirror. It makes it harder for me to see the side mirror BLIS and I have to really focus on it to see it. This additional BLIS light inside the cab helps that tremendously.
These next 3 pictures give you another drivers view of this mod both on and off.
Final thoughts. This mod ended up better than expected. While I would love this BLIS information in a HUD that just is not in the cards for the F-150 and I doubt that will happen anytime soon. I now find that when I get the thought to change lanes, I can quickly just glance my eye down to see if it is active or if I want to go further with the lane change mechanics. I do not have to take my eyes off the road and turn my head to find the mirror or the BLIS in the mirror only to have to refocus on the road if something is there. This ended up being a wonderful compromise on the BLIS position and with a small 5mm LED, it is not a distraction in the least.
I still have to do the passenger side and that will just be repeating the same process so I did not do that yet and worked on this write up. Although I believe the interior passenger side new BLIS light will be significantly easier to see, I do not believe it will have the same impact that the driver side has. You will still have to turn your head to see the light, but it will be easier to see.
Good luck if this helps anyone and as always, proceed at your own risk.
