Best Trailer hitch?
Jonathan
Aug 19, 2023
2021 F150 limited Powerboost
Hey all,
what’s the best hitch receiver for 2021 f150 limited.
I think max tow is around 10k.
most likely towing uhaul trailers or friends/family boats very infrequently.
I see lots of adjustable options; B&W, weighsafe, gen-y?
would appreciate everyone’s recommendations/reviews.
1lowcourier
Jeremiah
Apr 3, 2023
130
203
North Carolina
2023 F150 stx
Golf Course Construction
I've been really happy with my Bulletproof hitch. Lots of different options
ptr0687
Paul
Jul 22, 2021
101
171
US
Jeep Wrangler
Love my adjustable B&W. You have to call them and they'll send you a piece of metal to “lock” the hitch and keep it from being stolen. Its free and its in the instruction manual.
Old Bear
Jerry
Nov 13, 2022
220
269
Clarksville, TN
2023 Ford F150 King Ranch Powerboost
Information Technology
And just to overload you, I use the Weigh Safe with all three ball sizes with matched locking pins and the nice carry case. Keeps everything neat and tidy!
redline
Kyle
Oct 11, 2022
493
529
Calgary
2025 f150, BMW M3,VW Atlas
I am partial to the blue ox sway pro , that I use. I would like to try a weighsafe , they seem like a very interesting solution.
EricR
Eric
Jul 20, 2021
713
742
Boise, ID
I thought so too. Until reading the Weigh Safe specifications and seeing their WDH is 133.5 lbs – 146 lbs!
UGADawg96
Feb 28, 2021
3,436
6,039
JAX, FL
It really depends on the weights you're towing.
If under 7k, a regular Walmart 2" should be adequate.
If over 7k and needing a WDH, that's a whole different convo.
Davexxxx
Mar 25, 2023
69
1,276
1,359
MO
Thats for the heavy weight. The middle weight is still quite beefy but according to their spec sheet, mine weights 108 lbs.
Pros.
I like having the gauge a lot. So much better than guessing and hoping. Though I do wish it was in finer increments.
Once your measurements are put into the app and saved, its so simple and fast to use, you can literally adjust for each load. Loosen the lock nut, move the adjusting screw to what the app tells you to dial the gauge in to, tighten the lock nut. You're set. No taking anything back apart, or washers to guess with.
Porposing? Whats that? There was zero. Same for sway. I felt the bumps and the wind but only once, per incident.
Cons.
Its heavy. Having the gauge and super easy design, costs weight.
Because of the design, the truck's computer confuses the adjustment mechanism as the ball. Messes with the camera guidance a little. There may be a calibration adjustment I can make but I haven't dug into it.
This may not be fair to call it a con but it is at least a question mark but at this point, its kinda my fault.
Using the app alone, once we got to the Cat Scales, there was less weight on my front axle than I anticipated. The good news, is that it sent it to the trailer axle. It wasn't a problem driving, or even eyeballing but I wish when I set it up, I had also followed Ford's measurement procedure, as a confirmation. I will do that but I'll have to take it to a paved parking lot somewhere to do it.
Would I buy it again?
Since I want maximum adjustability and plan multiple trips across the Plains and the Rockies, yes.
For a couple semi local trips to the boat dock per yr? No, I'd choose something lighter and cheaper.
Aron
Aron
Jan 26, 2022
731
904
Virginia
Civil Engineer
A second vote for the blue ox sway pro that I use for my 6500lb travel trailer. I've had one since 2016 and it's worked pretty well for me. Yes, porpoising can happen, especially on concrete pavement with expansion joints, but it doesn't seem to be a safety issue...just annoying. I'd rather have the quiet operation and deal with the occasional porpoising than the constant metal-on-metal squealing from those friction-activated WDHs. I like it so much that I'm planning on buying a second one to replace the first one that I've pretty much worn out over the last 7 years.
However, in @Limitedlifestyle 's situation, that (or any WDH) might be overkill. I doubt that any Uhaul trailer would be heavy enough to require a WDH. I don't know about boat trailers, but I suspect that many boats would be light enough to not need one, either.
EcoB259
GB
Mar 3, 2023
162
129
22 XLT S Crew
I also use the WeighSafe Middleweight. I like the tongue weight scale built in and it is easy to set up.
AAWhyte
Alex
Dec 11, 2021
192
203
Fort Walton Beach FL
2022 Lariat 5.0
PM
I have the B&W, like you will do, I use it infrequently but I am able to tow whatever I need with it. I have the three ball version. And it tucks away very nicely while not in use.
Calson
Jul 16, 2022
27
1,307
646
Monterey CA
2022 F-150
Hey all,
My 2022 with the Max Tow package has a hitch rated for 11,100 lbs with the use of a weight distributing hitch.
A great place for advice and to buy towing products is etrailer.com.
air2mag
Apr 18, 2022
348
385
Indiana
2022 Platinum
I also use the adjustable B&W. It’s the two ball version. It makes it much easier to go from horse trailer to boat trailer.
