honda250xtitan
Aug 10, 2024
83
70
Phoenix
2023 F150 XL Rattler
Had some scrap 1x1 1/8” angle from a gate project. And since the welder and grinder were out and I was already a mess, figured today was the day I tinker with this. Pop out 2 shutters per side. Cut 2 short pieces and bolted them to the active air dam brackets in 2 spots per bracket. (That’s 8 bolts in the 1/4x20 1” long flavor). Than cut a 15-16” long cross piece, eye balled it, tacked it, checked with the pod light, and welded it in. The only non reversible portion is using a cutter to trim back the plastic for the air dam shutters. A smaller bolt would eliminate this issue.
Anyways, my plan is to run a splitter harness from the oem fog harness.
Pics or gtfo….. feel free to copy, refine, and enjoy. These are junky Lasfit pods. BD, diode dynamics, and rigid should all work as well.
Ford F-150 Behind the grille LED pod mounts: DIY install IMG_1756
Ford F-150 Behind the grille LED pod mounts: DIY install IMG_1757
Ford F-150 Behind the grille LED pod mounts: DIY install IMG_1758
Ford F-150 Behind the grille LED pod mounts: DIY install IMG_1760
Ford F-150 Behind the grille LED pod mounts: DIY install IMG_1762
Ford F-150 Behind the grille LED pod mounts: DIY install IMG_1763
Ford F-150 Behind the grille LED pod mounts: DIY install IMG_1769
Ford F-150 Behind the grille LED pod mounts: DIY install IMG_1770
Ford F-150 Behind the grille LED pod mounts: DIY install IMG_1772
honda250xtitan
Aug 10, 2024
83
70
Phoenix
FloridaPhil
Phil
Oct 26, 2024
31
33852
2024 F150 XLT Supercrew
I like it! Clean look to it.
Is that the stock Ford emblem?
honda250xtitan
Aug 10, 2024
83
70
Phoenix
yes sir. just has a black vinyl overlay. did the same on the steering wheel and the tailgate emblem.
FloridaPhil
Phil
Oct 26, 2024
31
33852
Where did you get the overlay, if I may ask?
honda250xtitan
Aug 10, 2024
83
70
Phoenix
FloridaPhil
Phil
Oct 26, 2024
31
33852
TY!
Gatorbud
Jason
Sep 16, 2024
NoFlo
2024 RCSB F-150
That's a very slick install. I always appreciate guys that take the time to fab a solid install. Bonus points for sharing.
honda250xtitan
Aug 10, 2024
83
70
Phoenix
It was crazy simple vs other small lighting projects I’ve done. The active shutter system is super helpful for mounting stuff lol. Also don’t look too close at those bird sh1t welds.
wife’s 4runner has a piece of extruded aluminum with 3 Baja design XL pro’s mounted on it. Than 2 brackets extend from that bar through the lower grille into the bumper cavity, which than get bolted to 2 tall mounts which than go down to the frame rails. That was a pain.
I also realize I should’ve put this in the lighting forum…newb.
anyways, the starkey harness showed up. Cut off the deutsch connectors, added my 2 pin weather pack ends and reversed polarity, lights work as they should ( not well cause they’re China knockoffs of diode dynamics, but free is free)
FloridaPhil
Phil
Oct 26, 2024
31
33852
Awesome look and great work getting there. I'd be proud of it :)
btw, I got the front/back logo stickers from KJM so thank you. And, my experience with them was outstanding.
Installing them tomorrow and will take before/after pics.
honda250xtitan
Aug 10, 2024
83
70
Phoenix
nice....theyre a vinyl. not a sticker, make sure you use a heat gun during install and after to fully get them to stick on.
FloridaPhil
Phil
Oct 26, 2024
31
33852
Yep, understood. The instructions they supplied are pretty good and luckily, this is not my first vinyl rodeo! :)
