Harelegger
I ordered mine without the bed utility option. Too much coin for lights and other stuff I didn't need. I just wanted the lights and not the other stuff but that wasn't an option. So I installed the factory parts (two light assys and the switch). When I pressed the button the high lamp (by the top brake light) came on so I knew the hot wire from the kick panel to the BCM was there. That's when I knew I just needed to do a few changes in forscan. Voila! They work!
Check this thread out:
https://www.f150gen14.com/forum/threads/2022-lariat-cargo-light-wiring-harness-parts.8683/page-8
What did you need to do in Forscan? Imade sure the Lincoln experience was disabled but that didn't solve the problem.I ordered mine without the bed utility option. Too much coin for lights and other stuff I didn't need. I just wanted the lights and not the other stuff but that wasn't an option. So I installed the factory parts (two light assys and the switch). When I pressed the button the high lamp (by the top brake light) came on so I knew the hot wire from the kick panel to the BCM was there. That's when I knew I just needed to do a few changes in forscan. Voila! They work!
