Battery charger recommendations
Kurt V
Kurt
Dec 21, 2023
Ivins, Utah
2023 Powerboost
I got a new to me 21 f150 king ranch with the 3.5 eb. I guess I need to charge the battery but my old charger isn’t compatible with the AGM batteries. Any recommendations on which charger to purchase or ones to stay away from?
Thanks
I really like this charger. Good for AGM batteries and won't overcharge. Safe to leave on indefinitely.
Amazon.com: TowerTop 2/10/25 Amp 12V Smart Car Battery Charger, Fully Automatic Battery Maintainer with Engine Start, Auto Desulfator, Battery Repair, Winter Mode, for AGM, STD, Gel, Deep Cycle Batteries : Automotive
Ghurst
Ghurst
Greg
Feb 21, 2024
50
Indiana
21 f150 3.5 eco boost king ranch
Carpenter
Thanks for all the responses! Guess I’ll check them all out and make a decision! Hoping I start getting some updates soon!
AndreB
Andre
Jan 1, 2024
43
31
Province of Quebec, Canada
2023 F150 Lariat 502a Star White Metallic 157" WB
I also use the Noco Genius Gen 5 charger. The Gen 5 series is totally sealed and has an AGM setting (which is remembered after being selected), so doing a permanent install under the hood is no problem. There is a great location on the right hand side of the radiator holding tank for a permanent install of the charger. I also installed 2 Noco permanent plug adapters (gcp1) below the head lights (one plug on the right "for the engine block heater" and one plug on the left "for the Noco charger"). I drilled a 2inch hole on either sides of the plastic portion of the front bumper (below the head light and above the metal part of the front bumper), remove the plastic portion of the bumper (2 bolts on both inner sides of the front wheel well, then un clip front left side to right side from front wheel to front wheel). This to make sure that the 2inch holes are located where there is more space behind the holes. I now have a permanent plugging solution for the engine block heater and the charger. See the following pictures for a clear visualisation.
Ford F-150 Battery charger recommendations IMG_5118
Ford F-150 Battery charger recommendations IMG_5119
Ford F-150 Battery charger recommendations IMG_5121
Ford F-150 Battery charger recommendations IMG_5120
Ford F-150 Battery charger recommendations IMG_5122
Ford F-150 Battery charger recommendations IMG_5110
Ford F-150 Battery charger recommendations IMG_5109
gb7FRz26
Aug 23, 2021
120
104
North Texas
2021 F150 XLT SuperCrew Short Bed, 2010 Prius
A NOCO Genius 5 has been connected to my battery for 1 year 4 months now (~28,000 miles) and gets plugged in every night. Set it and forget it, it remembers the last setting.
https://amazon.com/dp/B08G3NVR1N/
Non-affiliate, no tracking product link.
It's $80 right now, I paid $65 when it was on sale - and NOCO stuff goes on sale at least a couple times a year.
nezff
Apr 8, 2022
485
363
Louisiana
2022 F150 Lariat 4x4 Supercrew 5.0 Space White
Firefighter
I'd like to know what Amp selection you guys use to charge your agm batteries? I have a 22 f150 lariat. Bought the viking charger which has a agm setting. I have it set to agm and 8 amps right now. I've read 15amp setting would be too much? I'll attach pics.
Ford F-150 Battery charger recommendations 20240415_152259
Ford F-150 Battery charger recommendations 20240415_152310
Ford F-150 Battery charger recommendations 20240415_152323
