Back-Off Flasher for 3rd Brake Light
TXAGENT
Law
Nov 15, 2020
35
36
2021 King Ranch 5.0 FX4 Screw
Bullshit Detector
Hi, I want to install the “back-off” brake light flasher on my 21 KR, but I can’t figure out the wiring on this LED 3rd brake light. I only need to know what wire feeds the brake portion.
Ford F-150 Back-Off Flasher for 3rd Brake Light B7C58F35-B323-4805-AB99-178AFB5D6D05
I loved having it on my 18 Lariat and would appreciate any direction. The manufacturer was unable to help.
I just have to splice the module in between the 3rd brake wire. Thanks in advance.
Pete6114
Pete
Apr 15, 2021
347
223
Ontario Canada
2021 F150, 2023 Lincoln Aviator
Retired Ford employee
Mechanics in the shop can tell you by looking it up in their Oasis Manual. Just ask. Otherwise, a test light should also do the trick
Zyvin
682
876
SC
2021 F150 Crew, FX4, Lariat
Should be pin #3 on the main connector. Easy way is to put a meter on it. Black is ground, the other two will either be the cargo or stop. Turn on the cargo lights and see if the orange or white has 12v.
Ford F-150 Back-Off Flasher for 3rd Brake Light 429A9F31-AF39-4678-848C-DE15A7A189BE
TXAGENT
TXAGENT
Law
Nov 15, 2020
35
36
Bullshit Detector
Thank you, the folks on this Gen14 forum are the best! I knew I could count on y’all for help.
TXAGENT
TXAGENT
Law
Nov 15, 2020
35
36
Bullshit Detector
Thank you again! It was the third pin(orange wire, black was negative. It flashes 5 times then holds.
Back-Off XP Flasher for 3rd brake light.
