Armrest Not Staying Up In Open Position
Smitdog
Smitdog
Sep 18, 2020
361
282
Gainfully Retired
For all those having a hard time trying to pry up the spring ends, use a very small and thin flat blade screwdriver. You will be upside down and contorted a bit, but the result is worth it!
Doggy-Dog
Ted
Apr 10, 2021
151
119
Western Michigan
2018 Pacifica Limited & 2021 Loaded Lariat
Tried that and even used a wood chisel that has a thinner point. No such luck with those flat end springs.
But, we do have some success. I took my Vise-Grip pliers and grabbed that flat spring and pinched the hell out of it and managed to get it pulled up enough to get the nickels in place. If you have a second person to insert the nickels it would be MUCH less of a job. Lid stays up better but not as good as it should if Ford would have put the correct spring in place.
vriggy_3
Darin
Apr 19, 2021
Des Moines, IA
2021 Ford F-150 Lariat, 2005 Ford Mustang GT
I was able to cram a couple pennies under each end using this method a couple weeks ago. Ergonomically, it's very hard to get leverage on the springs to sneak a coin under, but it does stay up much better now. I was able to pull the passenger side out with a needle-nose for one penny, but had to revert to a small screw driver and do some prying for the remaining pennies. Just takes a lot of patience.
Doggy-Dog
Ted
Apr 10, 2021
151
119
Western Michigan
No way could I get the other two nickels under the upper spring ends. So I removed the two on the lower part and used double sided tape on two nickels for each spring. I had to grunt to the max with the Vise-Grip pliers to get the double nickels in place. Now when I release the latch it pops up about 1/4 of its ;normal travel. Push it up and it stays open.
Thanks Hambone.
RayRay
Ray
Mar 19, 2021
223
316
Midland, On, Canada
2021 XLT SPORT SCAB 302A 2.7
Yup
That’s what I did today.
Needle nose vies grips worked well.
The nickels weren’t enough. Took those out and put in hex nuts that were just over double the thickness of the nickels.
Lid now stays up when on an incline.
As long as those nuts don’t pop out of there, should be all good.
Coacher
Jim
May 30, 2021
28
2021 F150 XLT SCREW 3.5 302a
I noticed a couple posters thinking Ford spec’d the wrong spring. I agree with an earlier poster who believes it was to prevent folks digging around in there while driving. It’s big and deep and taking your eyes off the road for a prolonged period of time could lead to disaster.
Two dimes worked for me.
Pete6114
Pete
Apr 15, 2021
156
122
Ontario Canada
2017 Explorer, 2021 F150
Retired Ford employee
Thought i had the same problem, but found that i hadn't opened the lid all the way. It does stay up!
cdberkman
Christopher
Jun 4, 2021
2021 Ford F150 XLT 302A Crew Cab Sport V8
I just tried and after 30 minutes and 5 attempts with every tool on my wall, removed the passenger side door, took out the engine, removed the left rear wheel deflated the right front, used a crowbar jackhammer and weed whacker. The springs will not budge (mine are flat too). I gave up. I hate being defeated, especially by a little spring. I just have to get the engine back in... yea, not sure why I pulled the engine.. Maybe if I disconnect the drive shaft, it will release tension on the center console spring, that may work.
Duckgumbeaux
Feb 24, 2021
Louisiana
2021 Platinum
it is not an easy process but does work. I removed the cover below the springs which was easy. I have the flat springs and used a pair of vice grip pliers to get the two nickels in the lower springs. Now for the fun part. After about 30 minutes with the upper springs and no luck, I went to the hardware store and purchased some needle nose vice grips. That worked very quickly and now my arm rest works properly.
On another note, I hate this site because it costs money to do crap I never thought of😃
Biocast
John
Jul 15, 2021
MI
2021 F150 Lariat Hybrid 7.2kW
Property Mgt
Great fix KartRacer25!!
Leaf FNIAM
Jun 15, 2021
ON, CANADA
F150 XLT Sport 2.7
I might have pulled a muscle or three but 10 minute and 10 cents and the arm rest stays open! Thanks for the tips!
Bbass5
Brandon
Jul 13, 2021
102
118
Birmingham
F 150
Ha, that’s so true! I have like 9 things in my Amazon cart for when my truck arrives thanks to this site
Shorty Antenna, Wireless Charger, Rear Seat Release, Bull Rings, Tailgate letters, etc…
Duckgumbeaux
Feb 24, 2021
Louisiana
2021 Platinum
Damn I forgot about rear seat release!
JeffC57
Jun 8, 2021
76
56
Kansas City USA
'21 F-150 Lariat Sport 4x4 SCab, '18 Linc MKZ Hyb
Retired Electrical Engineer
Advertisement
Advertisement
