Anyone remove rear blocks?
3DogKnight
Mar 22, 2021
33
355
429
Minnesota
2020 Escape Titanium - 2021 F150 XLT
100% retired
I have a Craftsman set 1/2inch drive set that I used, had them for a long time, so I don't know if they are are extra deep, or something not 'normal'. I will say I first tried my impact sockets, but that socket was not deep enough. Another option would be a crows foot.
Sorry about your head aches with the process. You will likely want to just order the shorter U-bolts anyway, as these are barely threaded enough to accomplish this job. You need to be careful to tighten them evenly otherwise you'll just bottom out the nut where the treads end. I would highly recommend a thick washer or 2 under each nut to ensure good clamp load.
A box end wrench might be a better option over crows foot. Way stronger. If clearance around nut allows.
12Lariat21
Jonathan
Mar 23, 2021
414
497
55374
2021 Lariat 502A
Engineering Manager
Hi,
Since you removed the blocks, have you noticed any difference in the handling? Does it understeer less?
I would be interested to know if there is any difference on high speed curves?
Thanks
I have the 157" wheelbase on my truck. And I haven't noticed any change in handling characteristics. I have a sweeping interchange I take everyday at 70 mph, posted 'recommended' speed is 50mph.
So over 157" with a 1 inch drop it's only changing the caster angle by ~0.36 degrees. Typical alignment specs allow for +/- 1 deg, so it's still within factory specifications.
With the spacer installed my truck ran fairly level with my camper hitched up, so I plan on adding airbag helper springs in the spring to maintain that, and prevent the rear from having a squat to it.
Charlieben
Tim
Jun 15, 2021
41
57
10536
2021 F150, 1991 Mustang, 1969 Corvette
I removed mine and added a lowering shackle. I used a 2 degree axle shim. The original ubolts were retained. 2021 RCSB
4×4 5.0 3.73 Rear.
bcso23
Scott
Dec 31, 2021
Bristol, TN
2022 F150 Lariat FX4
Retired LE
Hi Gents, short time viewer/first time poster...thanks to all who teach others before we screw it up.
Just purchased my '22 and it's got darn near a 4in rake, 37 1/2" or so in front x 41 1/2". Motofab 2.5" leveling kit arrived today, and I intend to remove the rear spacer, which should get me near level.
Anyone have torque specs for the ubolt nuts?
Anyone see problems with my plan?
ib_jigged
May 18, 2021
330
326
Thief River Falls, MN
2021 F150 XLT, 2013 Edge Limited, 2023 Explorer ST
I had 4 1/8" of rake on my 157" wheel base and I added the Motofab 2" level kit. I now have 1 7/8" of rake. Works perfect for when I have a trailer loaded and connected, sits just above level. I thought of removing the rear block as well, but then I would squat with any type of load.
bcso23
Scott
Dec 31, 2021
Bristol, TN
Retired LE
OK, going to do the Motofab install in the next couple of days and see how I like it.
Zyvin
682
876
SC
2021 F150 Crew, FX4, Lariat
Tighten the U-bolt nuts in a cross pattern in 4 stages.
Torque :
Stage 1: 30 lb.ft (40 Nm)
Stage 2: 59 lb.ft (80 Nm)
Stage 3: 89 lb.ft (120 Nm)
Stage 4: 111 lb.ft (150 Nm)
bcso23
Scott
Dec 31, 2021
Bristol, TN
Retired LE
Torque :
OK thanks! I'll hold off and see what the 2.5 up front does
GolfR
Mar 24, 2021
344
323
Maryland
2022 F150 KR PB
I didn’t remove the bock in mine but did add the blue sumo springs and it makes a huge difference when I’m trailering. I didn’t install the spacer so under normal load the sumo springs don’t touch but if you remove the blocks they may touch all the time and the ride might stiffen up.
bcso23
Scott
Dec 31, 2021
Bristol, TN
Retired LE
OK 2.5 inch Motofab leveling kit and 285/65/20 BFG K02's
Rear blocks are still in, a little over an inch rake, I'll probably keep it how it is. I love it and glad I went with the 2.5 height, brought the front end way up and the air dam actually looks good now.
Ford F-150 Anyone remove rear blocks? 20220105_115753
Ford F-150 Anyone remove rear blocks? 20220105_115826
Ford F-150 Anyone remove rear blocks? 20220105_132607
Zyvin
682
876
SC
Looks great and matches your house. I think the rake looks good, for some reason when this model has less than an inch of rake, they look nose high. Probably some visual trickery with the body lines.
brisch
Sep 27, 2021
52
61
Central OH
2009 F-150, 2022 XLT 302a SCAB
I haven’t had a chance to get pictures yet, we’re in snow town right now! But I did remove the rear blocks also. I had about 3.75” rake on a 2022 SCAB, 4wd, sport model. I think it looks a lot better, truck won’t be towing or even hauling too much so I’m not too concerned about squat later. So I removed them, bought 2wd u-bolts, and at the same time replaced the factory shocks with Bilstein 5100’s. Also torqued down with above specs, thanks @Zyvin !
Zyvin
682
876
SC
Nice. How do you like the 5100's? Do they have 2wd versions? 4wd only/ Just curious. I thought about trying some new rear shocks, just wanted to see if I needed to buy 2wd specific since my block is removed.
brisch
Sep 27, 2021
52
61
Central OH
Sorry, meant to put that in there. Yes, I bought 2wd 5100’s. @Stage3Motorsports recommended those because I did remove the block, they said the travel range would be better with 2wd versions.
dbtgt
Aug 30, 2021
63
35
Oklahoma
2021 F150 Lariat 501A, 2024 F150 501A on order
Hello folks,
I have a 145" WB Lariat 501A FX4 with Max Tow pkg. What is the downside to removing the spring blocks other than ride height while towing or carrying a load? I don't plan to tow or haul much. I would like to remove some of the rake without lifting the front. Are the blocks just simply spacers or are there ride quality, driveline , or warranty considerations?
