JeremyMTB
I have read and understand all the confusion about what benefit there is to the different tow packages when buying a Powerboost. It seems the higher level trims even reduce the delta more as most of it is included in the base package. I am trying to figure out what might be included when ordering a highly optioned powerboost in general. It seems that at a minimum I would need the Trailer Tow package over the Tow Technology package as it will increase the rating from 7k lbs to 11k lbs. I believe this might just be a sticker change but I plan to tow around 7k lbs so I want the sticker on the door.
I was hoping someone with the above truck (specifically the Trailer Tow package and not the Max Tow) might be able to shed some light on the following.
Does your truck have the 4150 lb axle?
Are all 4150 lb axles the full floating axles?
Do all 4150 lb axles have the bigger brakes?
What frame does your truck have?
Does your truck have the mono leafs in the back or is it the 3 leaf pack?
What hitch does your truck have?
Are the different rated hitches actually different or is it just a sticker? I have read that hitches with longer frame mounting arms help transfer weight from a WDH better. If the "heavier duty" hitch from the Max Tow package mounts the same it might not make much of a difference as we are fighting payload and not trailer weight.
