jthistle
Dec 1, 2024
Iowa
2023 F150 XLT
It’s the full kit in bag
Ideally I’d prefer to find just the module itself since I already have the wiring for TPMS/CAM/YAW so I could just attach & plug in but can’t find anyone selling it without the wiring/dummy port.
If you don't want it, I'll pay you to ship it here. I'm look for a full kit :D
CT24Atlas
Dec 27, 2024
2024 F150 XLT SuperCab FX4 5.0
However, there is nothing on the Super duty camera+TPMS+yaw set that I installed that would use this additional wire. Perhaps newer camera packages have something additional.
I just installed a LC3Z-1A189-CH (Supercedes -C camera only kit with pro trailer backup) dated Nov 06, 2024. The trailer side cable that connects to the 12 pin bumper connector has only 9 pins populated and the blue/white wire is not included in the main harness.
BrewDay09
Brian
Jul 7, 2024
CO
2024 F-150 Lariat
So the blue/white wire remains a mystery.
But I'm curious if there has been an upgrade with the new part number. Specifically, has the camera improved? The camera in the older kits is low resolution and extremely wide angle. Can you share your experience with this latest kit?
CT24Atlas
Dec 27, 2024
I don't have an older camera to compare it with but it does seem to be low resolution.
The camera in the -CH kit that I bought is PN: HC3J-19H391-CB and the box that it was in is dated 11-20-23 so it was on the shelf for a year before it was put in the -CH kit.
Broke Richard
Mar 31, 2025
2023 F150
New member here with a 2023 F150 Platinum Powerboost. Can someone help me confirm whether I'm looking at the correct harness here? I want to add TPMS to my buggy hauler trailer - don't care about the camera, just looking for TPMS.
Ford F-150 Any update on a Trailer TPMS system? 20250331_002019[1]
Buyer2021
Feb 9, 2021
44
2,750
4,975
TX
retired!
That does appear to be connector C439, and in your case it appears to be 'fully populated' with the wires required for both TPMS and cam. (y)
C439 being what will plug directly into the replacement 7+12-pin bumper socket you'll get with the TPMS kit.
If the 'connector' it's plugged into (under your finger) is simply a 'blank holder' with no wires beyond, that's it for sure.
Buyer2021
Feb 9, 2021
44
2,750
4,975
TX
retired!
@Broke Richard , here just FYI is a diagram to let you confirm you already have all of the wires to support your need ....
Ford F-150 Any update on a Trailer TPMS system? C439 DETAIL
Have Fun!
SAAUZ
Austin
Jan 26, 2022
45
30
Toronto
Current GLK350, MAZDA 3, SportTreck ST251VBH
Physiotherapist
Alright, got my bumper harness in tonight. Everything on the harness works, except I'm still getting a blue screen on my aux camera on the center display :/ Guess I have a bit more troubleshooting to do.
Wanted to mention a few things from my experience for others though. The job took me a couple hours, but I like to putz and take my time so I don't damage anything.
The backup sensors were tough to get the connectors off of at first. I was pushing on the wrong side of the latch lever. Slide the white part as described, then press on the wire side, not the sensor side, to move the hook. After doing 4 of them - sliding the white part took more force than pinching it to open the clip.
I found it was easier to just remove the license plate lights with the wire harness attached, then remove the harness clip and replace the light. The light just twists and pulls out, but the clip on the harness was tough for me to press to release.
The big connector above the spare tire was by far the worst. It wasn't clear to me that I had to depress the top of the clip before the hinge latch would open, and it took quite a bit of force to do so. Then, when swinging the latch up, the toe of the molding hits the frame underneath it, so you have to pull up on the connector to angle it a bit for the latch to move fully. Also, it does swing a full 90 degrees between closed and open. Here's a pic of what I mean:
thanks for the tip; I couldn’t figure out the big top connection either. And everything was covered in rust proofing film. The sensors and the camera were working. But the plate lights did not come on. I tapped on the exterior plastic a few times and the driver side turned on, but not passenger side
bgalakazam
Lubo
Jun 16, 2021
233
199
Colorado Springs
2021 F150 500A Lariat 4x4 5.0L
Can I get some advice on part numbers and the least I need to purchase to get trailer camera to work?
I want to use the prewired camera and existing 12 pin connector without buying the full Ford kit. Otherwise a $100 wireless camera makes more sense.My trailer is wired with 12 pin connector, but I don't have the tow tech package. Currently, I have the 7/4 socket and the following wiring underneath.
Ford F-150 Any update on a Trailer TPMS system? IMG_1005
Ford F-150 Any update on a Trailer TPMS system? IMG_1006
Ford F-150 Any update on a Trailer TPMS system? IMG_1007
Ford F-150 Any update on a Trailer TPMS system? IMG_1008
SomebodyInGNV
Feb 6, 2022
297
106
Gainesville, FL
You want to use the prewired camera, as in the one that came on your trailer? I think it won't work. A $100 wireless camera probably makes more sense, considering your requirements.
bgalakazam
Lubo
Jun 16, 2021
233
199
Colorado Springs
The stock wireless camera was replaced with this and wired. It looks like a Ford camera, but can't confirm. That's why I want to see if I can tap into the existing 12 pin harness already routed to the hitch.
Ford F-150 Any update on a Trailer TPMS system? Screenshot 2025-06-15 at 14.09.50
Buyer2021
Feb 9, 2021
44
2,750
4,975
TX
retired!
I'm not finding the 'stowed' C439 in any of your pics. That needs to be located and the number of wires into it counted to determine what you may need. Go back and look for that, these pics may help in your search:
Ford F-150 Any update on a Trailer TPMS system? TRUCK 01 - CONNECTORS BACK OF BUMPER
Ford F-150 Any update on a Trailer TPMS system? TRUCK 03 - CONNECTORS BACK OF BUMPER
While you're at it, please confirm that you have the following on your 12" display screen menu as it is now without the trailer cam connected (you don't need the tow technology package but you do need the 360-degree cams package, this is required to display the trailer cam view when it is connected):
Ford F-150 Any update on a Trailer TPMS system? TRAILER CAM ON CENTER DISPLAY MENU.JPG
Let us know what your find and we can go from there.
bgalakazam
Lubo
Jun 16, 2021
233
199
Colorado Springs
I can’t find it. Possible it’s not there at all?
No 360 cam package, base 500A Lariat.
is wireless the simplest solution at this time? I would have to dismount the wired one at back if the trailer. I couldn’t find any 12 pin to wireless solutions.
