Buyer2021
Feb 9, 2021
44
2,750
4,975
TX
retired!
There is a list of the various wiring kits on Page 45 of the 2024 Ford RV and Trailer Towing Guide:
Thanks for that. Just FYI ....
When I search by PN at parts.ford.com, comparing
  • LC3Z-1A189-A (cam+TPMS with Pro Backup Assist per description above)
  • LC3Z-1A189-D (cam+TPMS without Pro Backup Assist per description above)
the price is the same for both ($910.00 MSRP; $819.00 from my local dealer).
Long ago I ordered and installed LC3Z-1A189-A (cam+TPMS with Pro Backup Assist); it had everything needed for cam+TPMS and did not include a yaw sensor module (which was fine by me).
Leaves me wondering what, if anything, is different between those two combo kits .... :unsure:
jthistle
Dec 1, 2024
Iowa
2023 F150 XLT
So after replacing rear bumper harness. And then adding 5 wires to the harness (2 can bus for TPMS, and 3 video for aux camera) from c316 under hood through the firewall to under the dash c242c and c238. Couple forscan changes and I now have trailer TPMS and Aux camera working on my 302A non-360 equipped truck. So it it possible to do without the 360 IPMA.
At the IPMA c242C add pins #8, #9, #18. I used terminal's part # WT-1002. under hood connector is c316. pins #2, #3, #4. i used terminal part #WT-1013
Do you know what terminal part # is needed when adding the 2 TPMS pins to C316? I believe they are pin number 43 and 44. WT-1013 is too large.
Danevo
Dan
Apr 17, 2024
Alberta, Canada
2022 F150 XLT 302A BAP Powerboost
For pins 43 and 44 I used WT-1012 and also for pins 25 and 26 of c238 which you’ll probably need to do as well
CT24Atlas
Dec 27, 2024
2024 F150 XLT SuperCab FX4 5.0
The truck side harness with the 12 pin connector on my August built 2024 XLT with tow package and 360 degree cameras is a new revision. The part number on the harness tag is RL3T-13A576-AFG. In this harness, C439 (the truck side 12 pin connector) has wiring to 10 of the 12 terminals. The new wire is pinned to terminal 11 and is a blue wire with a white stripe. It is a heavier gauge than the other wires. Does anyone know what its for?
Ford F-150 Any update on a Trailer TPMS system? 1741614730965-87
Ford F-150 Any update on a Trailer TPMS system? 1741614639555-be
WMac
Mar 10, 2025
Richmond, VA
2021 F-150 Limited
Retired IT Director
Hello all. New member here, long time lurker. i have read the entire thread and made my purchase believing it was the correct one. I have a 2021 F150 502A with the max trailer tow package. I have added a Borla Dual Exhaust and know there is some kind of difference for single vs dual.
I purchased the camera/TPMS kit and wire kit:
ML3Z-13A576-TFA
LC3Z-1A189-A
Unfortunately the wire kit has been out of stock for two months. According to some parts websites ML3Z-13A576-TFA has been replaced by ML3Z-13A576-PK. Can anyone confirm if ML3Z-13A576-PK is the new wire kit I should order? Thanks!
BrewDay09
Brian
Jul 7, 2024
CO
2024 F-150 Lariat
The truck side harness with the 12 pin connector on my August built 2024 XLT with tow package is a new revision. The part number on the harness tag is RL3T-13A576-AFG. In this harness, C439 (the truck side 12 pin connector) has wiring to 10 of the 12 terminals. The new wire is pinned to terminal 11 and is a blue wire with a white stripe. It is a heavier gauge than the other wires. Does anyone know what its for?
I do not have the answer, but it is good to see they included the C439 connector at all in your build. My 2024 Lariat 501A with 360 cameras and tow package did not even have the C439 and I had to repin the C423 and make my own patch cable with a Molex C439.
This is a photo of the truck side of my C423 connector and I can see this blue/white wire in pin 33 (just left of the lower right corner). I assume that's the same one.
Ford F-150 Any update on a Trailer TPMS system? 20240707_115727
However, there is nothing on the Super duty camera+TPMS+yaw set that I installed that would use this additional wire. Perhaps newer camera packages have something additional.
SomebodyInGNV
Feb 6, 2022
297
106
Gainesville, FL
... The only question I have, is there ANY advantage to find/purchase/use the yaw sensor? ...
I found no benefit and I'm not the kind of person that scoffs at things like that.
I tried stickers on my previous trailer (21') and the yaw sensor on my current one (26'). The yaw sensor is better that stickers because the truck doesn't lose the connection (it loses sight of the stickers) but it's easier to just hold the steering wheel at the bottom.
If you find a cheap kit on eBay and it includes the yaw sensor, by all means install it. Maybe you'll find some advantage. But I wouldn't pay more to get it. You won't miss anything if you don't.
SomebodyInGNV
Feb 6, 2022
297
106
Gainesville, FL
.... "Unless" they upgraded the camera quality, they should be equivalent. ...
Have you seen any information to suggest they have? The camera is pretty low quality. The perspective makes everything much smaller than it would appear in a rear-view mirror, or even as it appears in the 360 cameras.
Buyer2021
Feb 9, 2021
44
2,750
4,975
TX
retired!
Well said, I totally agree (y)
rxsamg
Sam
Jan 30, 2025
62
78
Marlton, NJ
2022 Lariat PB Atlas Blue, 2022 GT500, 1997 SVT Mustang
I found a local guy selling a new in bag kit $75.....I might bite
BrewDay09
Brian
Jul 7, 2024
CO
2024 F-150 Lariat
Sadly no. But I can always dream.
rxsamg
Sam
Jan 30, 2025
62
78
Marlton, NJ
Is that a yaw sensor only kit? I would do that only if will bug you forever that you didn't.
It’s the full kit in bag
Ideally I’d prefer to find just the module itself since I already have the wiring for TPMS/CAM/YAW so I could just attach & plug in but can’t find anyone selling it without the wiring/dummy port.
