SomebodyInGNV
Feb 6, 2022
291
105
Gainesville, FL
Been looking here an there, not much options, but I have some time till next camping season.
It took me a few months to find one. I actually bought one a couple of years ago that was camera-only, but never got around to installing it. It had been opened but never installed. I later found the <$400 camera/TPMS kit. It was new-in-box and works as described.
I used to try to kludge stuff together but no longer do. I recommend not taking that approach in this case, even if you might be inclined to consider it for other projects.
One disadvantage of the Ford cameras is they're lower resolution than the Furrion I replaced and their perspective does not match what you would see in your rear view mirror. I find it acceptable because I was able to get rid of cab clutter that bothered me.
Buyer2021
Feb 9, 2021
44
2,724
4,943
TX
retired!
Oh yeah, IMO ditching cab-clutter with the integrated cam on the dash display is well worth the minor video quality compromise; the image is just fine for backing the trailer and spotting what's behind closer than the side-mirrors show when on the highway. With the integrated TPMS it's a wonderful system for RV folks! (y)
{tpc}
Anthony
Feb 12, 2022
27
605
308
Berkley, MI
Just a quick question, hopefully it fits in this thread. My new truck has the 7/4 connector, however I prefer using the Yaw Sensor. Is there a way to convert? I may try the stickers once again, but there is very little room on the tongue of my trailer to allow for proper placement.
SomebodyInGNV
Feb 6, 2022
291
105
Gainesville, FL
In short, probably yes, but in my experience, it's not worth the effort. I wanted the yaw sensor to work better than the stickers (which didn't) on my 26' travel trailer. It doesn't.
The camera/TPMS kits that Ford sells comes with a 12-pin socket and a 12-to-4/5 adapter. Your truck has to have the plug for the 12-pin connector tucked up behind the bumper. For a yaw sensor, it has to have at least 2 conductors. For the trailer/TPMS functionality, it needs more conductors (I don't know what the count is but it either has 2, or the full complement.)
I think you'll find it expensive and not worthwhile.
{tpc}
Anthony
Feb 12, 2022
27
605
308
Berkley, MI
Thanks for the info. I haven’t looked behind the bumper yet to see what’s there. I already have the yaw sensor and used it on my last truck, so I would just require the wiring in place and to purchase the connector.
SomebodyInGNV
Feb 6, 2022
291
105
Gainesville, FL
If you already have the yaw sensor and the harness has a plug for the 12-pin connector, all you need is the connector. I'd get that at a junk yard. Use anti-corrosion grease (I forgot the correct term) in the socket or it will corrode from exposure to elements from the road.
You may need a 7-to-4/5 pin adapter for use with 4- or 5-pin trailer connectors.
DNUGENTUSMC
Daniel
Jan 30, 2025
Cape Cod, MA
2021 F150 Lariat SuperCrew LB - Velocity Blue
US Space Force Contractor
Thanks to this thread I was able to get my harness swapped out in my 2021 Lariat and got the camera working for now. I already installed the TPMS sensors in the tires but haven’t had time to install the wiring into the trailer.
However, since swapping out my rear harness, my power tailgate does not work. I too a Quick Look and didn’t see anything obviously forgotten and unplugged, would anyone know what to look for specifically?
Buyer2021
Feb 9, 2021
44
2,724
4,943
TX
retired!
Review of the wiring diagrams (including connector faces and location diagrams) for the cam/tpms harness (C423 and others back to the bumper) and the power tailgate harness (C433 / 432 / 431, C425, C4002, C4003, etc) indicates none of those connectors / harnesses / circuits have anything in common.
IOW, everything on C423 (the huge 34-pin connector above the spare tire) is completely independent of the power tailgate system which has its own completely independent harness from the tailgate to the front of the truck.
But all of those connectors are located in the tight spaces where you were working to replace your cam/tpms harness.
Suggest that you carefully inspect all connectors in that area to ensure that nothing was inadvertently disturbed / dislodged, not just the specific connectors you meant to touch.
Good luck.
{tpc}
Anthony
Feb 12, 2022
27
605
308
Berkley, MI
Dielectric Grease? I was able to procure a 7/12 connector, and the 7 pin portion has a fair amount of grease in it already but the 12 pin portion is dry.
jthistle
Dec 1, 2024
Iowa
2023 F150 XLT
Does anybody know what the difference is between the ML3Z-1A189-F and ML3Z-1A189-BE trailer camera/TPMS kits? The -F variant has been discontinued but appears to be quite a bit cheaper if you can find one.
BrewDay09
Brian
Jul 7, 2024
CO
2024 F-150 Lariat
I can't find a difference in those two part numbers. The BE variant appears to be a replacement for the F variant. "Unless" they upgraded the camera quality, they should be equivalent.
Is there any reason you wouldn't use the Super Duty version of the kit? I have the camera + TPMS version (LC3Z-1A189-D) working on my 2024 and no issues with the kit. It can be found for less than the F-150 kits and appears to be equivalent.
My only challenge was that Ford seems to have gone cheap on the tailgate harness and did not include a few wires and the connector to go to the 12-pin. I chose to repin and add the wires/connector myself because the correct harness wasn't available at the time (not for the faint of heart). Make sure your truck has the connector before proceeding or you may also need to replace the harness.
jthistle
Dec 1, 2024
Iowa
2023 F150 XLT
I found the F-150 kit new for $400. That's the only reason I'm going with that over the super duty kit. I also need to swap the rear bumper harness because I only have the 2 wires at the 12-pin. Harness is coming soon-ish
rxsamg
Sam
Jan 30, 2025
62
78
Marlton, NJ
2022 Lariat PB Atlas Blue, 2022 GT500, 1997 SVT Mustang
So, after reading & rereading a million pages in this thread, and some very helpful guidance from @Meterman (Jim) I believe I have everything needed to setup, just need to wait for a nice warm day to install. Thank you to everyone who thoroughly documented virtually every step with pics of what I needed to acquire & how to install.
2022 Lariat PB acquired few weeks ago. I have the 12 PIN plug, but the truck wiring only has 2 wires in it (must have been wired for Yaw sensor, but there were stickers included & no Yaw sensor?)
Ford F-150 Any update on a Trailer TPMS system? IMG_6163
360 cams already have the trailer cam soft button, but well versed in ForScan if needed.
ML3Z-13A576-PB (found online, single exhaust / 6 parking sensor kit where I'll remove or tie up the 2 farthest self park ones not needed for my truck)
Ford F-150 Any update on a Trailer TPMS system? IMG_6314
LC3Z-1A189-A Cam/TPMS/ with Yaw connector (Scored a sealed kit on facebook marketplace for dirt cheap!)
Ford F-150 Any update on a Trailer TPMS system? IMG_6311
The only question I have, is there ANY advantage to find/purchase/use the yaw sensor? I haven't even brought my trailer out of winter storage yet to try the stickers. It's an 18ft open car hauler that will be transporting the racecar to various tracks.
Ford F-150 Any update on a Trailer TPMS system? IMG_5972
Ford F-150 Any update on a Trailer TPMS system? IMG_6235
