I learned a bit more. Another forum (ford-trucks) has a thread about TPMS with heat in their Super-Duty subforum. Apparently, temp display was introduced in 2022. One of the owners there state that sensors from 2019 display temps in a '23, so it's the truck, not the sensor.Hmm... mine has no indicator of temp. Maybe because I didn't drive it, yet? I only got it configured in the storage lot. What FORScan settings did you change?
Edit: my truck is an XLT 301A. Perhaps the instrument panel doesn't support that?
I had to add 3 wires to the harness and a couple forscan changes to enable the aux cam. And the camera works on my non-360 truck. My truck also didn’t have the wires in harness for TPMS can bus. So I had to add those too. Your truck had the can bus wires so it’s possible the aux cam wires might be there. In which case you would just need to make forscan changes to get it to work. IPMA is easy to look at so you could check the grey connector for wires. Mine only had 3 originallyBummer.. I was worried that was the case. I've never got mine to work but the tire monitoring is nice. time to trade her in on a 360 equipped truck lol
Yea its the long grey one. yoyre missing the wires too. I had to add the 3 wires to that coonector and run under hood to get the camera to work.Any idea which connector I should be looking at? There is a long grey one with only 2 wires populated.
no its c242c. i had to add 8, 9, 18Is this the wiring diagram for the Grey plug? I'd assume 6, 9, 10 if this wiring diagram is correct
