Buyer2021
Finally back to close out my successful 5th-wheel trailer TPMS+rear view cam installation, previous post of my rig and goals is here, then a second post of partial progress here.
Recap of starting point
2022 Lariat (full specs in signature block below) already showing Trailer Tire Pressure menu item on IPC and showing Aux Cam selection on 12" display; 7/4 pin bumper sockets; without all wires to the 12-pin harness stashed behind the bumper.
Recap of goals
I'm very happy with how this turned out, it really is nice for my 5th-wheel rig.
Again, huge thanks to the folks contributing info to this thread, especially @GChurch
Recap of goals
- Keep the 7/4-pin bumper sockets for my 8' utility trailer (4-pins) and 17' utility trailer (7-pins with brakes)
- Add a 7/12-pin socket inside the bed for my 5th-wheel RV with TPMS+Rear Cam
- Ford Accessory Trailer TPMS+rear view cam kit LC3Z1A189A; this includes 4-wheel trailer TPMS, rear view cam, all needed harnesses, and the 7/12-pin socket for the truck; I did not get the version with Yaw Module because the F150 (unlike SuperDuty) does not support backup-assist for 5th-wheel trailers.
- Ford ML3Z-13A576-TFA wiring harness; this replaced my OE rear harness to get all wires to connector C439 at the rear bumper; the harness had support for 6 proximity sensors, I clipped-off the last on each end because my Lariat only has 4 proximity sensors in the rear bumper.
- Nichols Manufacturing Straight Harness & Mounting Box for 2020-2023 SuperDuty; this harness is a plug-and-play extension from C439 to the back of the 12-pin socket installed in the bedside; custom ordered to 7ft length; it also includes a mounting box for the 7/12-pin socket installed in the bedside; this avoided much tedious splicing of the OE harness and reduced my fabrication work for the bedside socket mounting (I cut-down the flange on the Nichols Box to fit my specific bedside location space). Nichols Manufacturing does great work, their custom-length harness and standard mounting box are beautiful pieces, service was very prompt .
- Curt 56070 7ft 7-pin Tee Extension Harness; this extends the 7-pin harness to the bedside while also leaving the bumper 7-pin socket functional
- Misc: 6mm aluminum rivnuts installed in the bedside for the mounting box; I stole the 6mm black torx bolts holding my 120-VAC outlet to the bedside for mounting the Nichols box (will order replacements from my dealer).
