JoeDimwit
In response to the questions thread.... questions thread
The numbers on DCFC are accurate, the extended battery will charge faster than the standard battery. Apparently, the on oard chargers also handle the charging control, not just converting the AC to DC. So, in effect, the truck has 2 smaller batteries each with their own current flow and control when charging. Even at a DCFC charger.
I was not able to get measurements for how far the mirror to mirror width is, they are understandably concerned about the idea of a metal measuring tape anywhere near their show vehicle.we were allowed to stick our head into the truck, and I got a few pictures of the interior, but no touching. At all. The Mirrors do fold in, and there is a trailer package with the extended mirrors. The standard ones look to stick out about 10 inches from the A-pillar.
The bed liner looks like itâs sprayed in, no one could tell me what material it is.
The headlights are Active Matrix, but they arenât sure if they are disabled by software like the Mach-E.
The Lightning is a nameplate, and will be available in various12 inch trim levels. The one they had here was a Platinum.
I didnât ask about 110v charging, because the size of these battery packs is going to make the charge rate of 110 WAY too slow. My Mach-E would take 96ish hours to charge from empty to full on 110v, and these battery packs are bigger.
Before you ask, they wouldnât tell me the size of the battery pack, just that it is larger than the Mach-E.
The 12 inch landscape screen is standard, the 15 inch portrait screen is an upgrade that comes standard in some trims.
The question everyone wants to know the answer to is how far will it tow⌠they would not give an answer. Several people asked while I was there, we all got âThere are a great many variables that affect tow range, we can not give an accurate answer at this timeâ.
There is not a plan for a âFord Charging Networkâ at this time. The plan is to partner with Electrify America. Charging with a trailer attached is going to depend on the stations setup, and Ford can recommend, but not require setups for stations.
I know this doesnât answer all the questions, but I also hope it helps.
Joe
now for the picturesâŚ
Joe
Joe
Joe
