Amber DRLs?
fxxkintallguy
Kyle
Mar 16, 2021
47
Los Angeles, CA
Website
www.instagram.com
2021 F-150 XLT FX4 5.0L 302A 5.5 SB
Does anyone know if its possible to change the DRLs from white to amber? If so, is there a tutorial online somewhere about it? Would it probably require me to switch out the actual LEDs to amber or RGB ones?
KBKEITH
Dec 9, 2020
962
943
2022 F-150 XLT SCREW 5.5, BAP, 3.5EB
I work for a semiconductor company and I personally work in the unit that deals in LEDs for the auto industry.
I just opened up a 2021 F-150 lamp here at work. The DRL consists of two light pipes that couple light from a small PCB with what appears to have two LEDs (or two small multiple LED clusters) mounted to it. I’ll have to find the PCB because it was removed a while back for some benchmarking.
Let me try and find this PCB and report back.
KBKEITH
Dec 9, 2020
962
943
I was able to find the board. I was close, there’s a two LED array for one light pipe and a 4 LED array for the second pipe.
Ford F-150 Amber DRLs? 4150CF41-18CE-4B43-AA6F-098CE91CB786
This photo shows the PCB in the headlamp housing:
Ford F-150 Amber DRLs? F9CC3D64-4A4A-4B01-AC49-79BEB479074C
This photo shows the two separate light pipes that couple the light from the LED arrays:
Ford F-150 Amber DRLs? 53E506F8-26FD-4CA6-8BE3-3915F9F2D3F2
This photo shows the assembled position of the light guides to the PCB:
Ford F-150 Amber DRLs? 94E5C81A-3407-4F8B-96CD-EDC3E6ABFE2A
Closer view:
Ford F-150 Amber DRLs? 5CFCF614-7137-454D-AA4E-EEB260573141
And finally the middle section of the headlamp that incorporates the two DRL light guides:
Ford F-150 Amber DRLs? 7987B566-838D-4B98-B498-D5A11DB6857C
You could remove and replace these white LEDs with amber. These are Nichia brand LEDs, so you’d have to get the same Nichia device only in amber. White is more efficient than amber, so the amber devices will not be as bright as the white.
Also, this PCB is a copper core board which is used to help with the thermal management. You’d have to have access to the right equipment to be able to remove and replace LEDs from this type of substrate. Takes a lot of heat.
fxxkintallguy
fxxkintallguy
Kyle
Mar 16, 2021
47
Los Angeles, CA
Website
www.instagram.com
Wow that was SUPER informative @KBKEITH! Thank you for all of that information, that helps way more than you know haha.
So with all that being said, I don't think I want to go in and mess with removing the LEDs. My normal hobbyist soldering iron probably can't handle that kind of heat output.
Are those LEDs just white? Or are they RGB?
Do you think putting an amber film on the ends of the light tubes might work?
KBKEITH
Dec 9, 2020
962
943
You’re welcome! It’s what I do for a living so I am more than happy to share. ??
The LEDs are white. No RGB for this application.
Yeah, a soldering iron unfortunately would not work here. The solder pads are completely on the bottom of the device. You would need at minimum a really good hot plate and ideally a good reflow oven.
The idea of an amber film could perhaps work. It would be worth a shot if you decide to take out a lamp and disassemble it.
Pinero
Jordan
Feb 2, 2021
52
46
Down the bayou.
2021 Lariat Sport 5.0 SCREW FX4
High Voltage Technician
I’m sure diode dynamics will come up with an RGB board for these. I had them do some amber c-clamps for my 2013. This should be even easier for them.
PungoteagueDave
593
791
33435
May I ask why? Aren’t there regs?
CommoSGT
Ken
Mar 26, 2021
197
148
Kentucky
2016 F150 Lariat SCrew, 2021 F150 Lariat SCrew
@KBKEITH Dude, if you aren't an engineer and haven't written an RCA (root cause analysis), you should be. Awesome write up!
John_C
Nov 24, 2020
158
145
Illinois
2021 F150 XLT 302A PowerBoost
Ford F-150 Amber DRLs? 20210412_155639
I also love the look of amber DRLs.. I enabled the turn signals and fogs as DRLs in forscan, and I think it looks a lot better already. Now I just need morimoto to make a headlight for the new f150s.. Lol
Ford F-150 Amber DRLs? 20210412_155523
Stefanolimotta
stefano
Apr 14, 2022
67
21 f150
Construction
I think if you have the led head lights you should be able to swap them for the raptor head lights they have the amber led weather you have a the xlt 302 head lights or the lariat 502 either head light from the raptor should work
Porpoise Hork
Bret
Aug 27, 2022
1,013
1,045
IT
An easier option than reflowing the board with different diodes may be to use theater lighting gel and adapt a LED lens housing to hold the gel film against the light pipes. Might even be able to design and 3D print something from ABS or polycarbonate to do the job. Still requires taking the headlight assemblies apart, but a lot less risky than reflowing the board.
