ashtank
Ashton
Sep 16, 2021
Indiana
‘16 F-150 SCREW 3.5 Eco
I am setting my expectations conservatively to avoid disappointment. If I can get 100 miles in the winter on the ER battery, without pre-conditioning, I will be happy (Wife's Mach-e will be plugged in most nights - she has a longer commute).
As for a heater - it is effectively certain that some kind of battery heater will be there. I think the only question is if it is resistive, a heat pump, or some combination.
You’re really setting an expectation for your range to be 1/3 of advertised range in the winter? The Lightning will be my first EV. I fully expect a range hit in the winter as well, but was sort of still anticipating 200+ in winter, not 100. Hmmm
Advertisement
sotek2345
Tom
Jun 7, 2021
444
403
Upstate NY
2016 F150 Screw 2.7l, 2019 Mustang GT350
40 percent to 50 percent reduction is what people have been seeing on the Mach-e. 100 is a 66 percent reduction, but the minimum I need for it to be a viable vehicle. I would also rather be surprised than disappointed.
bboy_72
Bob
Aug 22, 2021
64
77
Denver
F150 Lightning
For real? A 50% reduction in battery on a cold day? How is that even usable?
sotek2345
Tom
Jun 7, 2021
444
403
Upstate NY
Yeah, unfortunately (on really cold days). The battery doesn't work as well and the heater pulls a lot of juice. Note: This depends on what you consider cold. 0F has a much bigger impact than 30F. Preconditioning can help to offset some of this (heating the battery and car while still plugged in).
Here is a thread on a Mach-e forums discussing it.
https://www.macheforum.com/site/threads/new-job-new-car.6225/#post-174839
greenne
Nathan
Jul 13, 2021
229
292
Niskayuna, NY
F150 Lightning(reserved)
I was gonna say, Tom yours(and mine) definition of COLD is pretty skewed...that upstate NY thing....
biers
Thomas
May 21, 2021
30
31
SW Washington
eGolf
There are two primary factors with EV range in the cold. One is the capacity Will be limited due to cell chemistry at lower temps. This should be pretty constant across all EVs. Simple solution is to garage your vehicle and pre condition it.
The second factor is running the heater. Simple solution is to use seat warmers over the power hungry resistive heater. This reduction should be much lower (percentage wise) that your typical EV. That is because the Lightning will get around 2 m/kWh vs a car that gets 4-5 kWk. My Pacifica hybrid will use up to 8 kW to run the heater. That will burn through my 16 kWh battery MUCH faster than it will burn through a 160 kWH Lightning. Only real world testing will show. But if I get less than 75% of 230 or 300 miles in the winter with my garages truck I will be shocked. Not disappointed but shocked.
sotek2345
Tom
Jun 7, 2021
444
403
Upstate NY
What can I say, I like cold. Anything over about 60 is just too hot. 30 is light jacket weather. Cold starts around 10 and really cold is when you are at -20 or so!
greenne
Nathan
Jul 13, 2021
229
292
Niskayuna, NY
I'm the same way....drives my wife nuts but I start sweating at 65deg!!
Sgt Beavis
Rick
May 20, 2021
162
148
2021 Wrangler Rubicon and 2018 Mini Cooper S Count
overpaid computer nerd.
I'm not 100% certain on this. But there have been reports that the battery heater is resistive.
Villageidit
May 19, 2021
30
43
Tennessee
2017 Ram 1500, 2008 Honda Element,
Spent years in the 1000 Islands, cold is relative.
metroshot
Pat
Aug 26, 2021
150
91
West Covina, CA
2018 Honda PHEV
Network Tech
Cold weather has many detrimental effects on the range as I have been driving a 17kWh PHEV for 3 years now.
Cold weather causes battery chemistry to decrease capacity and use of climate controls (heating) uses up a huge amount of energy.
Also with colder months, seat heaters and headlights cause more drain during the darker months.
Many drivers in northern US and Canada experience about a 50% drop in capacity on a daily drive during the fall/winter months.
Pre-conditioning the cabin while plugged into a L2 charger will help offset the cabin heating as well as a heated garage while charging.
Canadians get a battery warmer standard, while US customers get none - very strange that they could not make it an option for Honda.
I hope Ford will put in battery warmers standard for the Lightning....
minirx7
Ed
May 13, 2021
100
95
Toronto
I have a deposit on the Cybertruck and teh Lightning. Only had my F150 2 months but would love to have an electric truck.
Question is, how much payload/tow capacity does the Lightning have REAL WORLD. My truck as 1729lbs payload and can comfortable tow my 30' Jayco with 7000lbs GVWR. Wonder if the lightning can even tow that much.
Also, want to know how towing impacts range. On the tesla, it drops the mileage to over 50%. The good thing about tesla is the tons of superchargers around, but with the Ford, they dont have that type of netwrok. CHeck out MArque Browns review comparing the tesla to the mach e and the issues they had with Charge AMerica!
EV is the future, and i loved my 2018 Leaf SL... i can totally move over to EV, but the range sucks so bad in the winter.
fitek
Peter
Aug 17, 2021
34
Washington state
Ford Transit 350EXT
If you watch the Sandy Munro videos he expects a 30% drop in range when towing. More if towing uphill. No comment on cold weather but looks like that Mach E thread has the data you need.
LightningShow
Sep 1, 2021
83
49
MA
'12 Ford Flex/'19 Chevy Bolt/'09 Porsche Boxster
I'd be pretty shocked if Ford was sandbagging on range by 100 miles. That just doesn't make sense. If they said 300 was their target and they hit 325 EPA people would be ecstatic. If they hit 400 then people would probably be wondering why they didn't advertise a 350 or 375 target. Range is money. If they are getting 400 on prototypes they'd probably reduce the battery capacity of the production vehicle to be more in line with what they advertised as the target. I'll eat my hat if the ER battery will get a legitimate 400 mile range.
That being said, careful driving adds significantly to range. A 300 mile range will probably get you close to 400 if you drive the speed limit, particularly on the highway, and/or do more 'around town' driving than highway. My Bolt has 238 EPA range but will get more like 350 for driving under 50 mph. I drive 90% highway miles at ~70mph and it meets the EPA range. It will get ~300 if I dial the highway speed back to 60mph. So, it depends on how important that range is to you. Driving technique makes much more of a difference in EVs as compared to ICE.
Advertisement
Advertisement
