sugarray
I began the HSW upgrade on my 23 501A Lariat SCrew. I saved as built data in Forscan, unhooked the negative terminal on the battery, then removed the airbag. I swapped out the SCCM and HSW. When I restarted to make the Forscan changes I had a ABS low voltage and Air bag low voltage indicator and trouble code. I updated the new SCCM with the saved as built SCCM data, made the APIM and other Forscan changes, then drove the truck. I was able to clear the ABS code and it remained off the the Air bag warning persists.
Thoughts?
My plan is to remove the Airbag and check all the connections, but will disconnect the battery again, so the "problem" will likely persist.
Thoughts?
