Adding trailer brake controller to 2024 F-150 Lariat
jshortt
James
Mar 27, 2025
Houston, TX
2024 F150 STX
Well after a botched dealer trip and all day without my truck, I'm now going to attempt this myself. I've read this entire thread about 6 times and think I finally have my head wrapped around it, new to the ForScan side of things so that's my biggest hurdle. I have a '24 F150 STX and plan to order kit #RLEZ19H332AA. I noticed in Livnitup's spreadsheet the "TRM" tab at the bottom says 21-23, is that coding still valid for a '24 or do I need something else?
Livnitup
Jul 15, 2020
262
666
SoCal
2021 F150 Platinum
Message me (or post) your vin and I'll give you the exact values & modules you should need and if it works then I'll add this to my common spreadsheet.
jshortt
James
Mar 27, 2025
Houston, TX
2024 F150 STX
That would be fantastic, thanks.
2024 F150 STX 2.7L 2WD
# 1FTEW2KP7RKE75110
Livnitup
Jul 15, 2020
262
666
SoCal
2021 F150 Platinum
# 1FTEW2KP7RKE75110
Try the values below in the modules indicated. Ignore whatever you have where the x's and dashes are. After making the changes reset the APIM (FORScan wrench icon).
IPC 720-07-01 xxxx xExx xx--
BCM 726-69-02 xxxx x1xx xx--
TRM 791-01-02 xxxx x3--
APIM 7D0-09-03 xxxx xxx4 xx--
IPMA 706-18-01 xxxx xxxC xx--
Please report back after you install and try these changes and tag me in the post.
jshortt
James
Mar 27, 2025
Houston, TX
2024 F150 STX
I should have also said to make sure you back up each module I listed above before any changes by clicking the "save all" button at the bottom of the screen.
Ok Ill give those a try.
I'm fixing to order the kit, so it'll be next week before I get around to making the ForScan changes.
jshortt
James
Mar 27, 2025
Houston, TX
2024 F150 STX
@Livinitup I went to order the Kit and the local dealer is telling me the -AA suffix has been replaced with -B suffix; -AA is available and -B is backordered. Can I complete this with the -AA kit or do I need to wait for stock of the -B Kit?
jwclack52
Jim
Dec 15, 2024
Bloomington, IN
2023 F150 XLT Ecoboost 3.5l
First of all, many thanks to all who have pioneered this addition. I've learned a lot from this and other threads. I installed ML3Z 19H332-AB in my '23 XLT (3.5L Ecoboost, 302a, Class IV hitch, 7050# GVWR Package, 3.31 Axle) and enabled three TCM settings in Forscan. I can change the gain with the dash-mounted switch. My problem is that I don't have a trailer w/ electric brakes yet but I want to test to see that it's functional. I bought an inexpensive Tekonsha trailer emulator, but when I squeeze the brake controller my truck tells me that no trailer is detected. I suspect that the "emulator" isn't doing a very good job of emulating. Does anyone know if there is an emulator that works with F150's?
Thanks in advance.
jwclack52
Jim
Dec 15, 2024
Bloomington, IN
Now I fear it's my fault. Looking at a couple of DTCs related to the trailer module:
Ford F-150 Adding trailer brake controller to 2024 F-150 Lariat F150 TRM U0423-56-08 Fault 2025-03-28 135251
Ford F-150 Adding trailer brake controller to 2024 F-150 Lariat F150 TRM Fault U2100-00-0B-03-28 135102
taylor-infotainment
Diamond Sponsor
Taylor
Nov 26, 2024
Oviedo, FL
Website
infotainment.com
17 Ford Fusion
Ford Sales Advisor
Hey guys Taylor with Infotainment here,
We are hard at work for this and this is something I want to divert our attention to fully. Most of our products are based on requests so if you are interested in something like this I would ask you to fill this out. We have a solution for 11-23 but a uptick of requests will force them to divert full attention into getting a solution for 24. And anyone interested in helping us beta test will have first access to this before it releases to the public. Stay tuned for future updates.
https://infotainment.com/product-live-interest-form/
Our 11-23 F150/F-250/F-350 solution.
https://infotainment.com/shop/inter...tegrated-electronic-trailer-brake-controller/
jwclack52
Jim
Dec 15, 2024
Bloomington, IN
Well, I was able to clear the U0423 w/ Forscan, but the U2100 keeps coming back. What "initial configuration" have I not completed? FWIW, squeezing the controller or pressing the brake does supply power to the electric brake pin.
haddad1
Jody
Jan 6, 2025
Houston
20214 F150 XLT
IT
Sounds like you didn’t back up the unit you installed by break petal before you swapped it (TRM). You can hookup the old one without removing the bolts, just plugin the old one and back it up. Need to back up the old TRM, install new, load old backup and make change for new before writing the new unit. Take a look at my past post, Should be pretty easy to follow along. TRM should NOT have a bunch of FFFF, this is what a new TRM before loading backup and writing looks like.
https://www.f150gen14.com/forum/thr...roller-to-2024-f-150-lariat.27174/post-610054
Ford F-150 Adding trailer brake controller to 2024 F-150 Lariat IMG_5055
haddad1
Jody
Jan 6, 2025
Houston
20214 F150 XLT
IT
Mine was a 24. Take a look at my post, it worked for me. I tried to document the process as best I can. https://www.f150gen14.com/forum/thr...roller-to-2024-f-150-lariat.27174/post-610054
jwclack52
Jim
Dec 15, 2024
Bloomington, IN
Thank you! I changed the one bit from 0 to 1 and that cleared the U2100, *but*... Before I had three entries in the IPC easy mode - after changing the as-built I only had one, trailer brake controller - no gain setting, etc. The truck responds to a squeeze of the controller and changes in gain setting (still says no trailer with my trailer emulator), but I'm a little worried about the absence of those two settings. Also, should I enable TBA? That wasn't there before.
Ford F-150 Adding trailer brake controller to 2024 F-150 Lariat TRM options Screenshot 2025-04-05 134926
NMHighDesert
Mar 15, 2025
NM High Desert
2024 F150 SC 4X4 XLT, 2.7
A couple of quick notes. I purchased the Motorcraft RL3Z-19H332-AA from Fairway Ford via Ebay (my local dealer said it was on backorder) and confirmed fitment with them by supplying my VIN for my December-build 2024.
Local dealer quoted $183 to install/program. At pickup, the invoice was $274 and they couldn't explain the increase, and they never called to express extra work was required/get approval, so they changed it back to $183. The installation looks good and all functions appear to work correctly, though I won't tow for another week or so.
