Doughecka
Well, didn't even have to remove the connector... So I'll need to do plan B and built a harness. And run it from point A to point B.haha thanks!
Checking that connector is super easy, just pop off the side panel and reach in and disconnect it quick to see if the wires are there or not.
If you do all your research, and looks like you definitely have already, it should be pretty simple for you once you wrap your head around all the Forscan changes needed. If you like puzzles, I shouldn't've made it so easy and made you go through and figured out all the values that needed changed on your own! Like Jesse and me had to do months ago when we forging the path for all this and figuring it out by trial and error haha.
Strange about your HD radio, there are some values in the ACM and APIM to change, you might just try to enable them to see if you have it, just not enabled for who knows why.
