Adding Co-Pilot Assist 2.0 with Forscan?
Je1279
Jared
Oct 23, 2022
1,128
964
Upstate NY
There is typically a red or white wire retainer clip on the front of the connector that needs to be removed to install any new pins. After the new pins are installed, you simply re-install the clip and re-connect the connectors.
ReverendQ
Kevin
Mar 26, 2023
526
620
SoCal
Website
www.linkedin.com
There is typically a red or white clip in the connector that needs to be removed to install any new pins. After the new pins are installed, you simply re-install the red clip and re-connect the connectors.
This video thread should be pinned (pardon the pun).
elcid98
John
May 8, 2024
37
58
Clover, SC
2023 F150 XLT 4x4 5.0
Escalation Engineer
Yes definitely. Thanks for all the help.
CCM installed, pigtail tapped into IPMA successfully and seated. CCM recognized now. Updated all forscan changes and added settings from IPMA to CCM, calibrated CCM this morning and now I get "pre-collision assist not available" in my dash and 2 IPMA codes
U0420 Invalid data received from Power Steering Control Module 'A'
- signal invalid
U2101 - Control module configuration incompatible
I cleared the codes and restarted but they keep coming up. I'm gonna step away from the truck for a while and then go back and check my forscan values to see if something needs to be changed.
elcid98
John
May 8, 2024
37
58
Clover, SC
Escalation Engineer
Ok update… I had to make some IPMA ForSCAN changes and everything works. I just tested it out and it was totally worth it. Just in time too… I have to drive to NY from SC to pick up my son at the US Merchant Marine Academy in a few weeks. Thanks again for all the support and writeups from everyone. It was a good learning experience too... this is my first Ford.
superfordman
Troy
Jun 29, 2021
914
900
NE CO
2024 Raptor 801A
Precision Ag Guru
Glad to hear, looks like your persistence paid off and got it whipped. You'll love it more and more the more you use it. These things drive themselves.
Throwaway
Aug 3, 2022
Home
Bronco Sport
Quick question, for bringing your truck in for dealer service work, is it possible to reset the modules to their AsBuilt configs? Or, does it even matter? I've seen some threads where people talked about the dealer FDRS system not being able to communicate properly after certain modules were changed.
elcid98
John
May 8, 2024
37
58
Clover, SC
Escalation Engineer
Yes you can easily go back to asbuilt if you back them up beforehand. You could potentially also download asbuilt file from ford but I haven’t tested this way. I think a lot of people reset ForSCAN to asbuilt before they go into service but I’ve read also that some dealers do t check if anything has been changed
tsklenar
Tyler
May 29, 2024
OKC
2023 F150 XLT
After installing everything, making the changes in FORScan, driving around, and leaving it sit for hours neither ACC or regular cruise control works. I also get the following warnings on the dash. Any idea where to start?
Ford F-150 Adding Co-Pilot Assist 2.0 with Forscan? IMG_8421
Ford F-150 Adding Co-Pilot Assist 2.0 with Forscan? IMG_8420
Ford F-150 Adding Co-Pilot Assist 2.0 with Forscan? IMG_8419
ReverendQ
Kevin
Mar 26, 2023
526
620
SoCal
Website
www.linkedin.com
All of those look like something is disabling your front camera to me. i.e. sun in the camera, hood up, bugs/dirt, etc. Anyway, if you have a 302A with 360 cameras like I do, you may want to check FORScan values against the spreadsheet I just sent you in PM.
BAPP702
Aug 25, 2023
51
Kentucky
'23 F150 XLT 302a 4x4 Black BAP Powerboost
My truck is not happy right now. Something with the BCM 726-16-01 code is causing ABS faults. Being a powerboost I feel like the value should be 190 but if it is only two digits how does that work? have a U2017 and U2101 ABS code and in the IPMA
Update: I changed the BCM code to 190 and no codes. I do have the pre-collision assist warning but that is probably because I need to do a 360 calibration even though I dont have 360. I still am not seeing the CCM.
davelj78
Feb 25, 2022
AZ
2023 F150 POWERBOOST
AVIATION
Has anyone seen if the bracket that the CCM mounts too is there when the bumper is removed.
Wondering if I need to order that bracket.
