Adding BLIS to STX?
Fuelin_Around
JJ
Feb 29, 2024
47
34
Central Illinois
2023 F150
Bump again. Would really love to do this to my RCSB XL.
kr33p302
Jan 24, 2023
South TX
22 F150
Got it done on mine glad I got it to work. You’ll need the tail light harness, blis tails and mirrors. Aside from that you’ll need forscan and someone to decode your vin to input the as built for the modules.
122
8,491
9,787
2022 307a PB
If you PMI the IPMA after installing the SOD modules, it should program them with the vin, granted it's cheaper to copy the vin via forscan.
Fuelin_Around
JJ
Feb 29, 2024
47
34
Central Illinois
2023 F150
Would you be willing to share the part number of the taillight harness that you purchased? I have all the other required parts.
Fuelin_Around
JJ
Feb 29, 2024
47
34
Central Illinois
2023 F150
SilverPigeon
Apr 27, 2022
1,062
1,245
Australia
'23 F-150 KR 5.0L 157"WB RHD "Emaciated Edition"
Sent the values.
For all, the values are just hexadecimal ascii codes and 4 addresses are needed to describe the 17-character VIN.
So,,in SODL or SODR the only config values are the VIN, split up as:
01-01: VIN 1-5
01-02: VIN 6-10
01-03: VIN 11-15
01-04: VIN 16-17
Having said that, I'll still do it for people if needed.
pelon222
Lupe
Feb 18, 2023
77
Tucson
2022 F150 RCSB
Engineering
I switched my taillight harness and added OEM LED taillights with modules, but dont see the modules in FORSCAN, is there anything else i should be checking or doing before they show up?
Fuelin_Around
JJ
Feb 29, 2024
47
34
Central Illinois
2023 F150
Which harness did you end up with? Really wanting to make this addition to my truck, but solid info is hard to find.
Tropictundra
Jan 8, 2024
Washington
F150 Stx 2023
I saw someone in the forum modifying the existing harness to make it work, but it would be nice to replace it with plug and play harness to make blis work. Is there a part number for it?
Fuelin_Around
JJ
Feb 29, 2024
47
34
Central Illinois
2023 F150
I'm having the exact same problem. I swapped to an OEM BLIS taillight harness, 2024 Raptor LED talilights with BLIS modules, and the SODL and SODR modules are not being detected by the truck or in Forscan.
Any ideas?
Matuglee
Mat
Mar 24, 2025
2021 Ford F150 STX
was anyone ever able to verify the harness model number needed?
Fuelin_Around
JJ
Feb 29, 2024
47
34
Central Illinois
2023 F150
I used the harness below and was able to get it to work finally.
Wire Assembly - Ford (ML3Z-13A409-FAJ)
Matuglee
Mat
Mar 24, 2025
2021 Ford F150 STX
Thanks man I appreciate it. Any forscan changes?
