Adding BLIS to STX?
Nolan
Mar 15, 2023
2021 f150 stx screw 4x4 3.5 eco beast
concrete estimator and project manager
So I have been digging and can’t find where this has been done but I know it has. Does anyone have info on adding blis to an STX I have the mirrors and I believe it’s just tails with blis modules and the correct wiring harness??
sbreech
Steve
Aug 15, 2021
134
207
Central Ohio
'21 F150 STX, Lead Foot Grey
Systems Administrator
I thought BLIS was standard on the STX. I have a 2021 Supercrew STX, with tow mirrors, and it came with the BLIS.
Nolan
Mar 15, 2023
What year?
Nolan
Mar 15, 2023
Sorry 21, you think you could pull the part # from the tail light harness
74
4,539
4,670
2022 302a PB, Mach E GTPE
I've seen XL taillamps on ebay with no BLISS so they are out there. Ford cheaps out on way too many things in the base XLs solely to try and get people to buy higher trims. People should be able to line-item every single option and only require other components when relied upon. Then the deletes on the platinum -- I mean they're basically a mix of 501 and 502 lariat parts, except for the steering wheel that's borrowed from the 302 XLT w/ a platinum badge on it.
I'm going to go out on a limb and say you're probably wired for it. Need to check your wires @carbonizedgreybeard. You didn't post your body style but this may still be relevant....
Check some of your harnesses for the wires it uses. If it's present in the tail lamp
Check C408's wires
Ford F-150 Adding BLIS to STX? 1679741232457
Ford F-150 Adding BLIS to STX? 1679742497149
Ford F-150 Adding BLIS to STX? 1679742538040
Ford F-150 Adding BLIS to STX? 1679742551878
35 and 40 may be for scale taillamps, 15 and 17 is power and signal to BLISS units.
Nolan
Mar 15, 2023
I’m not wired for it as my harness doesn’t have the plug on the passenger side that’s for the bed lights. I’m trying to make sure I order the correct harness for it, I believe it’s the same harness for the xlt halogen tail light trucks
Nolan
Mar 15, 2023
Not yet I have been busy with other projects, but if you do please keep it in the thread!
Nando7057
Fernando
Jul 12, 2023
37
41
NC
2023 VW GTI / 2023 F150
Any progress made on this?
This is something I'm interested in adding to my XL.
I have the harness from the factory for the Bed lights, I just need to check and see if the other harness pictured above is present.
Jesse-Infotainment
Jesse
May 27, 2021
3,729
5,903
All you need is the OEM Light harness.
One of the first things I did.
Nando7057
Fernando
Jul 12, 2023
37
41
NC
Lricaud81
Jun 20, 2023
40
545
192
Louisiana
2023 f150 stx fx4
You have the harness for bed lights on your xl. I have one too. Well stx but same thing. Which plug is it so I can look see if I have it. Did you plug in bed lights and it worked
Nando7057
Fernando
Jul 12, 2023
37
41
NC
Found a video on youtube that shows where the bed light plug should be.
Nolan
Mar 15, 2023
you know the part number?
I believe it’s ML3Z13A409AAJ
I also believe it is the harness needed for my bed lights to work??
